Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
View Cube Buttons, Access Through API
11 REPLIES 11
Message 1 of 12
750 Views, 11 Replies
Hi All
Is it possible to access the View Cube buttons through the API.
I would like to map them on to a macro run by my space explorer.
11 REPLIES 11
Message 2 of 12
Sorry, but the view cube is not currently
accessible through the API.
Brian Ekins
Autodesk Inventor API
href="http://blogs.autodesk.com/modthemachine">http://blogs.autodesk.com/modthemachine
Hi
All Is it possible to access the View Cube buttons through the API. I would
explorer.
Message 3 of 12
Hi Brian this is my code
Please try running the Function 'Positive90'
I am having Rotate the Model about the horizontal Axis.
I have no trouble with rotating the model about the up vector (vertical axis) which is the 'Positive90' function less the 'RotateMatrix90' sub.
But I can't seam to Rotate the Matrix to a position normal to the up vector so I can Rotate the Model about the horizontal Axis
Could you help me out on this one. I have actually be tiring on and off for years to do it but I just can't seem to get my head
around how the matrix translation works.
I am drawing a circle just as a reference until I perfect the code
I really work appreciate you time on this one.
As I said before. I would like to map them these functions onto run by my space Explorer
Option Explicit
'LoadBaseValues
Dim oApp As Inventor.Application
Dim oDoc As Document
Dim oView As View
Dim oCompDef As ComponentDefinition
Dim oClientGraphics As ClientGraphics
Dim oTransGeom As TransientGeometry
Dim MyCamera As Camera
Dim oCurvesNode As GraphicsNode
Dim oCenter As Point
Dim oNormal As UnitVector
Dim oTransformMatrix As Matrix
'LoadBaseValues
'DrawCircle
Dim oCircle As Inventor.Circle
Dim oCircleGraphics As CurveGraphics
'DrawCircle
'RotateCameraAbout
Dim oCurveEval As CurveEvaluator
Dim dPi As Double
Dim dIncrement As Double
Dim dCurrent As Double
Dim adEye(2) As Double
Dim adGuessparams() As Double
Dim adMaxDeviations() As Double
Dim adParams(0) As Double
Dim aenSolTypes() As SolutionNatureEnum
Dim adPoint(2) As Double
Dim oNewEye As Point
'RotateCameraAbout
Public Function Positive90()
LoadBaseValues
RotateMatrix90
DrawCircle
RotateCameraAbout -90
DeleteCircle
End Function
Public Function Negitive90()
LoadBaseValues
RotateMatrix90
DrawCircle
RotateCameraAbout 90
DeleteCircle
End Function
Sub LoadBaseValues()
Set oApp = ThisApplication
Set oDoc = oApp.ActiveDocument
Set oView = oApp.ActiveView
' Set a reference to component definition of the active document.
' This assumes that a part or assembly document is active.
Set oCompDef = oDoc.ComponentDefinition
' Check to see if the test graphics data object already exists.
' If it does clean up by removing all associated of the client graphics
' from the document. If it doesn't create it.
On Error Resume Next
Set oClientGraphics = oCompDef.ClientGraphicsCollection.Item("SampleGraphicsID")
If Err.Number = 0 Then
On Error GoTo 0
' An existing client graphics object was successfully obtained so clean up.
oClientGraphics.Delete
' update the display to see the results.
oView.Update
GoTo Continue:
Else
Continue:
Err.Clear
On Error GoTo 0
' Set a reference to the transient geometry object for user later.
Set oTransGeom = oApp.TransientGeometry
'The Camera is analogous to a real-world camera.
'You can define its position in space, the direction in which it is pointed and how it is tipped.
'You can also control the type of lens by setting the perspective angle.'
'Each time the Camera property of the View is used a new Camera object is returned.'
'The Camera object returned contains the current camera settings of the view.'
'This is important to understand because changing the camera may not behave as expected.
'For example the following code will result in no changes to the view contents.
Set MyCamera = oView.Camera
' Create the ClientGraphics object.
Set oClientGraphics = oCompDef.ClientGraphicsCollection.Add("SampleGraphicsID")
' Create a new graphics node within the client graphics objects.
Set oCurvesNode = oClientGraphics.AddNode(1)
Set oCenter = MyCamera.Target
Set oNormal = MyCamera.UpVector
' Create a matrix. A new matrix is initialized with an identity matrix.
Set oTransformMatrix = oTransGeom.CreateMatrix
End Sub
Sub DrawCircle()
' Create a transient circle object
Set oCircle = oTransGeom.CreateCircle(oCenter, oNormal, MyCamera.Target.DistanceTo(MyCamera.Eye))
' Create a circle graphics object within the node.
Set oCircleGraphics = oCurvesNode.AddCurveGraphics(oCircle)
ThisApplication.ActiveView.Update
End Sub
Sub RotateCameraAbout(ByVal dAngle As Double)
' Get the evaluator from the circle to get points along the circle.
Set oCurveEval = oCircle.Evaluator
' Calculate the angle to step with each increment.
' Define Pi
dPi = Atn(1) * 4
dIncrement = (dPi / 180) * dAngle
' Determine the position along the circle where the eye currently is.
adEye(0) = MyCamera.Eye.x
adEye(1) = MyCamera.Eye.Y
adEye(2) = MyCamera.Eye.Z
Call oCurveEval.GetParamAtPoint(adEye, adGuessparams, adMaxDeviations, adParams, aenSolTypes)
' Initialize the position using the current eye position.
dCurrent = adParams(0)
' Calculate a point on the circle using the current parameter.
adParams(0) = dCurrent + dIncrement
Call oCurveEval.GetPointAtParam(adParams, adPoint)
' Create a point that defines the eye position.
Set oNewEye = ThisApplication.TransientGeometry.CreatePoint(adPoint(0), adPoint(1), adPoint(2))
' Set the eye and apply the camera.
MyCamera.Eye = oNewEye
MyCamera.ApplyWithoutTransition
End Sub
Sub DeleteCircle()
On Error GoTo 0
oView.Update
End Sub
Sub RotateMatrix90()
Debug.Print MyCamera.UpVector.x
Debug.Print MyCamera.UpVector.Y
Debug.Print MyCamera.UpVector.Z
' Set the rotation of the matrix for a 90 degree rotation about the Z axis.
'I think the problem located here on the next line. **** ,oTransGeom.CreateVector(0, 1, 0) **********
' but I don't know how to fix it. I think the coordinates need to change as the up vector changes .
' Although I don't know how to do it.
Call oTransformMatrix.SetToRotation(3.14159265358979 / 2, oTransGeom.CreateVector(0, 1, 0), oCenter)
oNormal.TransformBy oTransformMatrix
End Sub Edited by: Stuartmp74 on Dec 13, 2008 5:09 AM
Message 4 of 12
Please post code using Rich Text
format.
Joe ...
Hi
Brian this is my code Please try running the Function 'Positive90' I am having
Rotate the Model about the horizontal Axis. I have no trouble with rotating
function less the 'RotateMatrix90' sub. But I can't seam to Rotate the Matrix
horizontal Axis Could you help me out on this one. I have actually be tiring
on and off for years to do it but I just can't seem to get my head around how
the matrix translation works. I am drawing a circle just as a reference until
I perfect the code I really work appreciate you time on this one. As I said
Option Explicit 'LoadBaseValues Dim oApp As Inventor.Application Dim oDoc As
Document Dim oView As View Dim oCompDef As ComponentDefinition Dim
oClientGraphics As ClientGraphics Dim oTransGeom As TransientGeometry Dim
MyCamera As Camera Dim oCurvesNode As GraphicsNode Dim oCenter As Point Dim
oNormal As UnitVector Dim oTransformMatrix As Matrix 'LoadBaseValues
'DrawCircle Dim oCircle As Inventor.Circle Dim oCircleGraphics As
CurveGraphics 'DrawCircle 'RotateCameraAbout Dim oCurveEval As CurveEvaluator
Dim dPi As Double Dim dIncrement As Double Dim dCurrent As Double Dim adEye(2)
As Double Dim adGuessparams() As Double Dim adMaxDeviations() As Double Dim
adParams(0) As Double Dim aenSolTypes() As SolutionNatureEnum Dim adPoint(2)
As Double Dim oNewEye As Point 'RotateCameraAbout Public Function Positive90()
LoadBaseValues RotateMatrix90 DrawCircle RotateCameraAbout -90 DeleteCircle
End Function Public Function Negitive90() LoadBaseValues RotateMatrix90
DrawCircle RotateCameraAbout 90 DeleteCircle End Function Sub LoadBaseValues()
Set oApp = ThisApplication Set oDoc = oApp.ActiveDocument Set oView =
oApp.ActiveView ' Set a reference to component definition of the active
document. ' This assumes that a part or assembly document is active. Set
oCompDef = oDoc.ComponentDefinition ' Check to see if the test graphics data
object already exists. ' If it does clean up by removing all associated of the
client graphics ' from the document. If it doesn't create it. On Error Resume
Next Set oClientGraphics =
oCompDef.ClientGraphicsCollection.Item("SampleGraphicsID") If Err.Number = 0
Then On Error GoTo 0 ' An existing client graphics object was successfully
obtained so clean up. oClientGraphics.Delete ' update the display to see the
results. oView.Update GoTo Continue: Else Continue: Err.Clear On Error GoTo 0
' Set a reference to the transient geometry object for user later. Set
oTransGeom = oApp.TransientGeometry 'The Camera is analogous to a real-world
camera. 'You can define its position in space, the direction in which it is
pointed and how it is tipped. 'You can also control the type of lens by
setting the perspective angle.' 'Each time the Camera property of the View is
used a new Camera object is returned.' 'The Camera object returned contains
the current camera settings of the view.' 'This is important to understand
because changing the camera may not behave as expected. 'For example the
following code will result in no changes to the view contents. Set MyCamera =
oView.Camera ' Create the ClientGraphics object. Set oClientGraphics =
oCompDef.ClientGraphicsCollection.Add("SampleGraphicsID") ' Create a new
graphics node within the client graphics objects. Set oCurvesNode =
oClientGraphics.AddNode(1) Set oCenter = MyCamera.Target Set oNormal =
MyCamera.UpVector ' Create a matrix. A new matrix is initialized with an
identity matrix. Set oTransformMatrix = oTransGeom.CreateMatrix End If End Sub
Sub DrawCircle() ' Create a transient circle object Set oCircle =
MyCamera.Target.DistanceTo(MyCamera.Eye)) ' Create a circle graphics object
within the node. Set oCircleGraphics = oCurvesNode.AddCurveGraphics(oCircle)
ThisApplication.ActiveView.Update End Sub Sub RotateCameraAbout(ByVal dAngle
As Double) ' Get the evaluator from the circle to get points along the circle.
Set oCurveEval = oCircle.Evaluator ' Calculate the angle to step with each
increment. ' Define Pi dPi = Atn(1) * 4 dIncrement = (dPi / 180) * dAngle '
Determine the position along the circle where the eye currently is. adEye(0) =
MyCamera.Eye.x adEye(1) = MyCamera.Eye.Y adEye(2) = MyCamera.Eye.Z Call
aenSolTypes) ' Initialize the position using the current eye position.
dCurrent = adParams(0) ' Calculate a point on the circle using the current
parameter. adParams(0) = dCurrent + dIncrement Call
oCurveEval.GetPointAtParam(adParams, adPoint) ' Create a point that defines
the eye position. Set oNewEye =
adPoint(2)) ' Set the eye and apply the camera. MyCamera.Eye = oNewEye
MyCamera.ApplyWithoutTransition End Sub Sub DeleteCircle() Set oClientGraphics
= oCompDef.ClientGraphicsCollection.Item("SampleGraphicsID") If Err.Number = 0
results. oView.Update End If End Sub Sub RotateMatrix90() Debug.Print
MyCamera.UpVector.x Debug.Print MyCamera.UpVector.Y Debug.Print
MyCamera.UpVector.Z ' Set the rotation of the matrix for a 90 degree rotation
about the Z axis. 'I think the problem located here on the next line. ****
,oTransGeom.CreateVector(0, 1, 0) ********** ' but I don't know how to fix it.
I think the coordinates need to change as the up vector changes . ' Although I
don't know how to do it. Call oTransformMatrix.SetToRotation(3.14159265358979
/ 2, oTransGeom.CreateVector(0, 1, 0), oCenter) oNormal.TransformBy
oTransformMatrix End Sub Edited by: Stuartmp74 on Dec 13, 2008 5:09
AM
Message 5 of 12
If we keep doing that, how will we ever get them to fix
the frikkin' plain text editor? Personally, I don't know what
is taking them so long, except maybe they don't know WTF
they are doing at AD. I suspect there is only ONE line of
code to change.
Joe Sutphin wrote:
> Please post code using Rich Text format.
> Joe ...
> wrote in message news:6089467@discussion.autodesk.com...
> Hi Brian this is my code Please try running the Function
> 'Positive90' I am having Rotate the Model about the horizontal Axis.
> 'RotateMatrix90' sub. But I can't seam to Rotate the Matrix to a
> my head around how the matrix translation works. I am drawing a
> circle just as a reference until I perfect the code I really work
> appreciate you time on this one. As I said before. I would like to
> map them these functions onto run by my space Explorer Option
> As Document Dim oView As View Dim oCompDef As ComponentDefinition
> Dim oClientGraphics As ClientGraphics Dim oTransGeom As
> TransientGeometry Dim MyCamera As Camera Dim oCurvesNode As
> GraphicsNode Dim oCenter As Point Dim oNormal As UnitVector Dim
> oTransformMatrix As Matrix 'LoadBaseValues 'DrawCircle Dim oCircle
> As Inventor.Circle Dim oCircleGraphics As CurveGraphics 'DrawCircle
> 'RotateCameraAbout Dim oCurveEval As CurveEvaluator Dim dPi As
> Double Dim adParams(0) As Double Dim aenSolTypes() As
> SolutionNatureEnum Dim adPoint(2) As Double Dim oNewEye As Point
> 'RotateCameraAbout Public Function Positive90() LoadBaseValues
> RotateMatrix90 DrawCircle RotateCameraAbout -90 DeleteCircle End
> LoadBaseValues() Set oApp = ThisApplication Set oDoc =
> oApp.ActiveDocument Set oView = oApp.ActiveView ' Set a reference to
> component definition of the active document. ' This assumes that a
> part or assembly document is active. Set oCompDef =
> associated of the client graphics ' from the document. If it doesn't
> create it. On Error Resume Next Set oClientGraphics =
> Err.Number = 0 Then On Error GoTo 0 ' An existing client graphics
> object was successfully obtained so clean up. oClientGraphics.Delete
> ' update the display to see the results. oView.Update GoTo Continue:
> Else Continue: Err.Clear On Error GoTo 0 ' Set a reference to the
> transient geometry object for user later. Set oTransGeom =
> which it is pointed and how it is tipped. 'You can also control the
> type of lens by setting the perspective angle.' 'Each time the
> returned.' 'The Camera object returned contains the current camera
> settings of the view.' 'This is important to understand because
> MyCamera = oView.Camera ' Create the ClientGraphics object. Set
> oClientGraphics =
> new graphics node within the client graphics objects. Set
> oCurvesNode = oClientGraphics.AddNode(1) Set oCenter =
> MyCamera.Target Set oNormal = MyCamera.UpVector ' Create a matrix. A
> new matrix is initialized with an identity matrix. Set
> oTransformMatrix = oTransGeom.CreateMatrix End If End Sub Sub
> object within the node. Set oCircleGraphics =
> RotateCameraAbout(ByVal dAngle As Double) ' Get the evaluator from
> the circle to get points along the circle. Set oCurveEval =
> oCircle.Evaluator ' Calculate the angle to step with each increment.
> adEye(0) = MyCamera.Eye.x adEye(1) = MyCamera.Eye.Y adEye(2) =
> MyCamera.Eye.Z Call oCurveEval.GetParamAtPoint(adEye, adGuessparams,
> adMaxDeviations, adParams, aenSolTypes) ' Initialize the position
> using the current eye position. dCurrent = adParams(0) ' Calculate a
> point on the circle using the current parameter. adParams(0) =
> dCurrent + dIncrement Call oCurveEval.GetPointAtParam(adParams,
> adPoint) ' Create a point that defines the eye position. Set oNewEye
> adPoint(1), adPoint(2)) ' Set the eye and apply the camera.
> MyCamera.Eye = oNewEye MyCamera.ApplyWithoutTransition End Sub Sub
> DeleteCircle() Set oClientGraphics =
> ' update the display to see the results. oView.Update End If End Sub
> Sub RotateMatrix90() Debug.Print MyCamera.UpVector.x Debug.Print
> MyCamera.UpVector.Y Debug.Print MyCamera.UpVector.Z ' Set the
> rotation of the matrix for a 90 degree rotation about the Z axis. 'I
> changes . ' Although I don't know how to do it. Call
> oTransformMatrix End Sub Edited by: Stuartmp74 on Dec 13, 2008 5:09 AM
Message 6 of 12
Done.
The file is an attachment too.
Option Explicit
'LoadBaseValues
Dim oView As View
'LoadBaseValues
'DrawCircle
'DrawCircle
'RotateCameraAbout
Dim dPi As Double
'RotateCameraAbout
LoadBaseValues
RotateMatrix90
DrawCircle
DeleteCircle
End Function
LoadBaseValues
RotateMatrix90
DrawCircle
DeleteCircle
End Function
On Error GoTo 0
oView.Update
GoTo Continue:
Else
Continue:
Err.Clear
On Error GoTo 0
End Sub
Sub DrawCircle()
End Sub
' Define Pi
dPi = Atn(1) * 4
End Sub
Sub DeleteCircle()
On Error GoTo 0
oView.Update
End Sub
End Sub
Message 7 of 12
In all likelihood, they're not going to fix it.
Joe ...
"Bob S." wrote in message
news:6090012@discussion.autodesk.com...
code to change.
> Joe ...
> oClientGraphics =
Message 8 of 12
I'm not sure what your exact requirements
are.  I looked through your code but it seems like you're basically trying
to fly the camera around a part using a circular path where the path can be at
any orientation.  Below is another implementation to do that.  There's
a function below that takes the view and an axis and angle that does all the
work.  The axis defines the axis of rotation and the angle specifies the
amount you want to rotate around.  The center of rotation is always the
current center of the view (camera target).  To play with different
rotations just change the vector defined for the oAxisVector
variable.
Public Sub Test()
    Dim oView
As View
    Set oView =
    ' Set the axis of
rotation.
    Dim oAxisVector As
UnitVector
    Set oAxisVector =
ThisApplication.TransientGeometry.CreateUnitVector(0, 1, 0)
    ' Define
pi.
    Dim dPi As Double
    dPi = Atn(1) *
4
    ' To animate the camera
rotation, specify a sequence of rotations.
    Dim iNumSteps
As Integer
    iNumSteps = 180
    Dim
dAngle As Double
    dAngle = (dPi * 2) /
iNumSteps
    Dim i As Integer
    For i = 1
To iNumSteps
        Call
RotateCamera(oView, oAxisVector, dAngle)
    Next
End
Sub
Public Sub RotateCamera(ViewWindow As View, Axis As
UnitVector, Angle As Double)
    Dim oCamera As
Camera
    Set oCamera =
ViewWindow.Camera
    ' Create a new
matrix.
    Dim oTrans As Matrix
    Set
oTrans = oTG.CreateMatrix
    ' Set the
matrix so it defines the rotation specified by the input
arguments.
    Call oTrans.SetToRotation(Angle, Axis.AsVector,
oCamera.Target)
    ' Transform the
camera data using the matrix.  The target of the camera will
stay
    ' fixed, but the eye point and the up vector can
change and need to be transformed.
    Dim oTempPoint As
Point
    Set oTempPoint = oCamera.Eye
Call oTempPoint.TransformBy(oTrans)
    oCamera.Eye =
oTempPoint
    Dim oTempUpVector As
UnitVector
    Set oTempUpVector =
oCamera.UpVector
    Call
oTempUpVector.TransformBy(oTrans)
    oCamera.UpVector =
oTempUpVector
    ' Apply the changes
to the view.
    oCamera.ApplyWithoutTransition
End
Sub
Message 9 of 12
Thanks a lot for the response Brian.
That is what I am after but I am trying to rotate it reletive to the screen not the Origin of the part or Assembly
I am guessing these line need to change
' Set the axis of rotation.
Dim oAxisVector As UnitVector
Set oAxisVector = ThisApplication.TransientGeometry.CreateUnitVector(0, 1, 0)
Any Ideas on how to make it rotate reletive to the screen.
X axis being left to right on the screen.
Y axis being bottom to top of the screen.
In other words your routine is great but I don't know at the time of rotation which way the Part or Assembly Orgins are facing
so in one case to make it rotate about the X axis reletive to the screen
I would use
But in another case to rotate it again about theX axis reletive to the screen
I would use
Set oAxisVector = ThisApplication.TransientGeometry.CreateUnitVector(1, 0, 0)
What I am have trouble with is working of how to program this.
What I am trying to do is rotate it about the x or the y axis reletive to the screen no matter what the orintation of the part is in.
Please help me out if you can. Edited by: stuartmp74 on Dec 16, 2008 1:23 AM
Message 10 of 12
Here's the code again but with a different sub that
calls the RotateCamera sub.  It creates the vector based on the current
camera.  There is an If statement where you can change which part is
executed by setting one of them to True and the other False.  This will
demonstrate the three possible standard rotations for a view.
Public Sub SpinViewTest()
    Dim
oView As View
    Set oView =
    Dim
    Dim oCamera As
Camera
    Set oCamera = oView.Camera
Dim oSiteVector As UnitVector
    Set oSiteVector =
_
oCamera.Eye.X - oCamera.Target.X,
_
oCamera.Eye.y - oCamera.Target.y,
_
oCamera.Eye.z -
oCamera.Target.z)
    If False
Then
        ' Spin around the vertical
axis.
        Set oAxisVector =
oCamera.UpVector
    ElseIf False
Then
        ' Spin around the horizontal
axis.
        Set oAxisVector =
oSiteVector.CrossProduct(oCamera.UpVector)
    ElseIf True
Then
        ' Spin around the line of
site vector.
        Set oAxisVector =
oSiteVector
    Dim dPi As Double
    dPi = Atn(1) *
4
    Dim iNumSteps As
Integer
    iNumSteps = 180
    Dim dAngle
As Double
iNumSteps
    Dim i As Integer
    For i = 1
To iNumSteps
        Call
    Next
End
Sub
Public Sub Test()
    Dim oView As
View
    Set oView =
    Dim
    Set oAxisVector =
0)
    Dim dPi As Double
    dPi = Atn(1) *
4
    Dim iNumSteps As
Integer
    iNumSteps = 180
    Dim dAngle
As Double
iNumSteps
    Dim i As Integer
    For i = 1
To iNumSteps
        Call
    Next
End
Sub
Public Sub RotateCamera(ViewWindow As View, Axis As UnitVector, Angle As
Double)
    Dim oCamera As Camera
    Set
oCamera = ViewWindow.Camera
    Dim oTG
    Set oTG =
Create a new matrix.
    Dim oTrans As
Matrix
    Set oTrans = oTG.CreateMatrix
    ' Set the matrix so it defines the rotation specified by
the input arguments.
Axis.AsVector, oCamera.Target)
Transform the camera data using the matrix.  The target of the camera will
stay
    Dim oTempPoint As
Point
    oCamera.Eye =
oTempPoint
UnitVector
    Set oTempUpVector =
oCamera.UpVector
    Call
    oCamera.UpVector =
oTempUpVector
    ' Apply the changes
to the view.
End
Sub
Message 11 of 12
Thanks a lot Brian, I have been trying to this since V5.3
I had a similar routine in Mechanical Desktop. That I used all the time.
Here is my final code if anyone wants to use it. (See Attached as well)
I am going to map the command onto my space explorer
Public Sub RCamAbtVertAxsPos90()
RotateMain "AbtVertAxs", 90
End Sub
Public Sub RCamAbtVertAxsNeg90()
RotateMain "AbtVertAxs", -90
End Sub
Public Sub RCamAbtHorAxsPos90()
RotateMain "AbtHorAxs", 90
End Sub
Public Sub RCamAbtHorAxsNeg90()
RotateMain "AbtHorAxs", -90
End Sub
Public Sub RCamAbtScreenPos90()
RotateMain "AbtScreen", 90
End Sub
Public Sub RCamAbtScreenNeg90()
RotateMain "AbtScreen", -90
End Sub
Public Sub RotateMain(AboutAxis As String, RotAngle As Double)
Dim oView As View
Set oView = ThisApplication.ActiveView
Select Case AboutAxis
Case "AbtVertAxs"
' Spin around the vertical axis.
Set oAxisVector = oCamera.UpVector
Case "AbtHorAxs"
' Spin around the horizontal axis.
Set oSiteVector = ThisApplication.TransientGeometry.CreateUnitVector(oCamera.Eye.x - oCamera.Target.x, oCamera.Eye.Y - oCamera.Target.Y, oCamera.Eye.Z - oCamera.Target.Z)
Set oAxisVector = oSiteVector.CrossProduct(oCamera.UpVector)
Case "AbtScreen"
' Spin around the line of site vector.
End Select
Dim dPi As Double
Dim dAngle As Double
Dim iNumSteps As Integer
dPi = Atn(1) * 4
dAngle = RotAngle
iNumSteps = 15 'used to slow rotation down a bit
Dim i As Integer
For i = 1 To iNumSteps
Call RotateCamera(oView, oAxisVector, dIncrement / iNumSteps)
Next
End Sub
Public Sub RotateCamera(ViewWindow As View, Axis As UnitVector, Angle As Double)
Set oCamera = ViewWindow.Camera
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
'Create a new matrix.
' Set the matrix so it defines the rotation specified by the input arguments.
Call oTrans.SetToRotation(Angle, Axis.AsVector, oCamera.Target)
'Transform the camera data using the matrix. The target of the camera will stay
' fixed, but the eye point and the up vector can change and need to be transformed.
Dim oTempPoint As Point
oCamera.Eye = oTempPoint
Dim oTempUpVector As UnitVector
Set oTempUpVector = oCamera.UpVector
Call oTempUpVector.TransformBy(oTrans)
oCamera.UpVector = oTempUpVector
' Apply the changes to the view.
End Sub
'Thanks again to Brian
Message 12 of 12
craigzcool
has there been any updates since this question was last asked - either in Inventor 2014 or 2015?
