Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
VS2010 Express Startup Application
2 REPLIES 2
gerhick
490 Views, 2 Replies
Hi all,
I'm just setting myself up on a new PC, and updating a few things along the way. I've gone from VS2005 to VS2010 express, and migrated my projects along the way. The migrated projects worked OK, but I've just started a new project and I can't figure out how to add a start up application for my project.
On the Debug tab in Project Properties, there's no option for startup application like there was in VS2005
Any ideas?
Thanks in Advanced
___________________________________________
Gerrard Hickson
Inventor CAD Administrator || Autodesk Inventor 2012 Certified Professional
Autodesk AutoCAD 2012 Certified Professional|| Bachelor of Technology (Mechanical)
PointZero Design and Drafting
2 REPLIES 2
gerhick
in reply to: gerhick
OK,
So I finally figured this problem out.
Details are here: http://through-the-interface.typepad.com/through_the_interface/2006/07/debugging_using.html
Now, I can't get the debugging to work, it doesn't hit breakpoints or display errors.
Cheers
Gerrard Hickson
ADNpati
Where did you find .vbpj.user file???????????????????????????????
Blowig my head
I feel like banging my head against wall
Mechanical Engineer
Inventor Applications Engineer
If my solution seems to remedy your problem, please press the Accept Solution button, Some KUDOS -
