Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
VBA -> C#: Get me the scalestring!
2 REPLIES 2
546 Views, 2 Replies
I don't get it why it doesn't work ..
In VBA I have the following code that works fine:
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As DrawingViews
    Set oSheet = oDoc.ActiveSheet.DrawingViews
    Dim oCount As DrawingViews
    Set oCount = oSheet
    Dim oItem As DrawingView
    Set oItem = oSheet.Item(1)
    MsgBox ("Scale: " & oItem.ScaleString)
Trying this in C# (connecting with VS and also have a reference to "Autodesk.Inventor.Interop.dll"), I get stuck at the point where I want the "Item(1)". The Object Drawing View doesn't know any "Item". Looking in the object catalog there is only a "this[int]" between Count an Type. I guess the "this[int]"-stuff is what I'm looking for, but I don't have any idea how to handle with this.
Does anyone of you guys have an idea??
2 REPLIES 2
jeff.pek
Hi -
You're on the right track. In C#, you use list[index] instead of list.Item(index).
So, for your case, it would be something like:
DrawingDocument oDoc = inventorApplication.ActiveDocument as DrawingDocument;
DrawingView firstView = oDoc.ActiveSheet.DrawingViews[1];
Note that indexing is still 1-based, and not 0-based.
Jeff
in reply to: jeff.pek
Works like a charm! Thanks!
