hi,
is there anyone has an example of this? I dont have any idea how DimensionsToRetrieve works.
thanks.
If you can find the desired dimension constraints in your model then the rest is straightforward. You should add these constraints to the object collection and call Retrieve method using this object collection as the second argument.
The following VBA sample retrieves the first two dimentions from the first sketch in the part model that is referenced by the first drawing view in the first sheet in the active drawing document.
Private Sub RetrieveTest_1() Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet Set oSheet = oDrawDoc.Sheets.Item(1) Dim oView As DrawingView Set oView = oSheet.DrawingViews.Item(1) 'object collection for dimensions to be retrieved Dim oTO As TransientObjects Set oTO = ThisApplication.TransientObjects Dim oObjColl As ObjectCollection Set oObjColl = oTO.CreateObjectCollection 'fill the object collection with some dimension constrains 'Here we use sketch DimensionConstraint objects. Dim oDoc As PartDocument Set oDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument Dim oDef As PartComponentDefinition Set oDef = oDoc.ComponentDefinition Dim oDimConstraints As DimensionConstraints Set oDimConstraints = oDef.Sketches.Item(1).DimensionConstraints Dim oDC As DimensionConstraint 'add first two constraints to the collection Set oDC = oDimConstraints.Item(1) Call oObjColl.Add(oDC) Set oDC = oDimConstraints.Item(2) Call oObjColl.Add(oDC) 'retrieve subset of dimensions Call oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oView, oObjColl) ' 'retrieve all the dimensions ' Call oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oView) End Sub 'RetrieveTest_1
It is possible to locate desired dimension constraint object by model parameter name or you may use attached attribute. See the overview article "Working with attributes" in Inventor API help.
Thanks a lot!
I will take a look at it.
Does this only work for parts? I'm able to make it work for a single part but I'd like to expand this to include retrieving dimensions within assemblies. Is this available throught the API?
Inventor 2013
If the sketch you want to access is within the context of the assembly, you just need to add one more branch, e.g.
if part...
Dim oPartDef As PartComponentDefinition
Set oPartDef= oDoc.ComponentDefinition
if assembly...
Dim oAssDef As AssemblyComponentDefinition
Set oAssDef= oDoc.ComponentDefinition
If the sketch is within the context of the occurrences (sub-assembly/part) of the top assembly, you need to access the sketch by Occurrence.Definition.
Hope this explains.
Please review the attached (C#) code. I am able to retrieve the constraint I'm looking for within the sketch, but I'm getting an Unspecified COM Exception on the last line of code where the dimension is retrieved. Both parameters within the Retrieve method have valid values.
Inventor.TransientObjects transObjs = Application.TransientObjects; Inventor.ObjectCollection objColl = transObjs.CreateObjectCollection(); Inventor.AssemblyDocument mainCabAsm = hwyAsm as Inventor.AssemblyDocument; Inventor.ComponentOccurrence carSlingAsm = mainCabAsm.ComponentDefinition.Occurrences.ItemByName["CarSling:1"]; Inventor.ComponentOccurrence platformAsm = carSlingAsm.Definition.Occurrences.ItemByName["650AE:1"]; Inventor.ComponentOccurrence plywood = platformAsm.Definition.Occurrences.ItemByName["Plywood:1"]; Inventor.PartComponentDefinition pCompDef = plywood.Definition as Inventor.PartComponentDefinition; Inventor.DimensionConstraints constraints = pCompDef.Sketches[1].DimensionConstraints; Inventor.DimensionConstraint dimCon = null; if (null != constraints) { foreach (Inventor.DimensionConstraint d in constraints) { if (d.Parameter.Name=="PlatformDepth") { dimCon = constraints[1]; objColl.Add(dimCon); } } } else { } sheet.DrawingDimensions.GeneralDimensions.Retrieve(vw, objColl);
Xiaodong.liang,
I am trying to retrieve the dimensions from a sketch in item 1 of the an assembly. I modified the above code. I keep getting a Method Retrieve of General Dimension Failed error. Can you take a look for me?
Sub Retrieve()
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim oDoc As AssemblyDocument
Dim oDef As ComponentOccurrence
Set oDef = oDoc.ComponentDefinition.Occurrences.Item(1)
Dim oDoc1 As PartDocument
Set oDoc1 = oDef.Definition.Document
Dim oDef1 As PartComponentDefinition
Set oDef1 = oDoc1.ComponentDefinition
Set oDimConstraints = oDef1.Sketches.Item("Sketch1").DimensionConstraints
End Sub
