I'm trying to make a script to replace all instances of a part/assembly in an assembly with a new copy of that file. So I'm trying to make an improved version of the "save and replace component" feature since it will only replace one part. I've created an ideastation post to have "save and replace component" be able to replace all instances of the part you replacing, but I want this feature in the mean time.
So far the script prompts you to select a part, enter a few filename, and does a check on the new file name. I need help with saving a new copy of the selected part and replacing all instances of the original part in the assembly. Is there a simple way to replace all instances or will it require a loop through all components and checking the filename then replacing ones that match, if so that's something I should be able to do. Thanks.
Public Sub Save_Replace_All() 'Checks if open document is assembly If (ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject) Then MsgBox "This is NOT an assembly document!", vbExclamation Exit Sub End If Dim oPart As ComponentOccurrence Dim opartdoc As Document Dim oPartdoc2 As Document Dim NewFileName As String Dim NewFilePath As String Set oPart = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select the part to save and replace all.") Set opartdoc = oPart.Definition.Document NewFileName = InputBox("What is the new file name for " & filename_noext(opartdoc.FullFileName) & "?", "New File Name", filename_noext(opartdoc.FullFileName)) NewFilePath = ThisApplication.FileLocations.Workspace & "\" & NewFileName & "." & file_ext(opartdoc.FullFileName) If (fileExists(NewFilePath)) Or (NewFileName = "") Then MsgBox ("Error! Either file exists or no filename given") Exit Sub End If 'needs to save a copy of opartdoc as newfilepath, found this in another script but the script editor doesn't like it opartdoc.SaveAs(newfilepath,False)
'This replaces the selected part but I need to replace them all Call oPart.Replace(NewFilePath, False) End Sub
Solved by pball. Go to Solution.
Well I finally got everything working. Found out how to save a copy of the selected part/assembly and replace all instances in the active assembly. So it won't affect sub-assemblies or parent assemblies if you are editing a sub-assembly.
Public Sub Save_Replace_All() 'Checks if open document is assembly If (ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject) Then MsgBox "This is NOT an assembly document!", vbExclamation Exit Sub End If Dim oPart As ComponentOccurrence Dim opartdoc As Document Dim oPartdoc2 As Document Dim NewFileName As String Dim NewFilePath As String Set oPart = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select the part to save and replace all.") Set opartdoc = oPart.Definition.Document NewFileName = InputBox("What is the new file name for " & filename_noext(opartdoc.FullFileName) & "?", "New File Name", filename_noext(opartdoc.FullFileName)) NewFilePath = ThisApplication.FileLocations.Workspace & "\" & NewFileName & "." & file_ext(opartdoc.FullFileName) If (fileExists(NewFilePath)) Or (NewFileName = "") Then MsgBox ("Error! Either file exists or no filename given") Exit Sub End If Call opartdoc.SaveAs(NewFilePath, True) Dim fd As DocumentDescriptor For Each fd In ThisApplication.ActiveEditDocument.ReferencedDocumentDescriptors If (fd.FullDocumentName = opartdoc.FullFileName) Then fd.ReferencedFileDescriptor.ReplaceReference (NewFilePath) Next End Sub
And fileExists
I don't have your function in the project. But it still works if I delete functions.
It will be better if it uses ThisApplication.CreateFileDialog.
Well here are the couple of functions I use in this script if anyone is interested.
Also apparently that is my old version, since I did add a file save dialog afterwards.
Public Sub Save_Replace_All() On Error GoTo err: 'Checks if open document is assembly If (ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject) Then MsgBox "This is NOT an assembly document!", vbExclamation Exit Sub End If Dim oPart As ComponentOccurrence Dim opartdoc As Document Dim NewFileName As String Dim NewFilePath As String Set oPart = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select the part to save and replace all.") If (oPart Is Nothing) Then Exit Sub Set opartdoc = oPart.Definition.Document 'Create a new FileDialog object. Dim oFileDlg As FileDialog Call ThisApplication.CreateFileDialog(oFileDlg) 'check file type and set dialog filter If opartdoc.DocumentType = kPartDocumentObject Then oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt" ElseIf opartdoc.DocumentType = kAssemblyDocumentObject Then oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam" End If oFileDlg.InitialDirectory = ThisApplication.FileLocations.Workspace oFileDlg.filename = filename(opartdoc.FullFileName) oFileDlg.CancelError = True On Error Resume Next Call oFileDlg.ShowSave If err Then Exit Sub ElseIf oFileDlg.filename <> "" Then NewFilePath = oFileDlg.filename End If ThisApplication.SilentOperation = True Call opartdoc.SaveAs(NewFilePath, True) ThisApplication.SilentOperation = False Dim fd As DocumentDescriptor For Each fd In ThisApplication.ActiveEditDocument.ReferencedDocumentDescriptors If (fd.FullDocumentName = opartdoc.FullFileName) Then fd.ReferencedFileDescriptor.ReplaceReference (NewFilePath) Next Exit Sub err: ThisApplication.SilentOperation = False On Error GoTo 0 Resume End Sub Function filename_noext(spth As String) 'Returns filename without extension from full path If spth <> "" Then filename_noext = Mid(spth, InStrRev(spth, "\") + 1, InStrRev(spth, ".") - InStrRev(spth, "\") - 1) Else: filename_noext = "" End If End Function
I am trying to use this macro and its coming up with an error message that says compile error can't find project or library.
I am very very very raw with macros and just trying to get this to work to save me some steps.
This idea has been implemented within Autodesk Inventor 2024.2. Please review the Inventor 2024.2 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
