Is it possible to read the current setting for drawing projection (1st or 3rd angle) from the style library associated with the currently open drawing file (idw)?
Any help would be appreciated
regards
Mark
Inventor Pro 2014
Solved by Robert..F. Go to Solution.
Here you go:
Sub DrawingStyle()
Dim oDoc As Inventor.DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oStyle As Inventor.DrawingStandardStyle
Set oStyle = oDoc.StylesManager.ActiveStandardStyle
Debug.Print oStyle.FirstAngleProjection
End Sub
