Thx for you help, Bill.
What I did with MyDefault is exactly what you described here.
Everthing works fine . The only problem is: when I open and close IV, I
still have to run LoadPM manually (Alt + F8)
Anyway, IV can load it automatically???
Thanks.
wrote in message news:5087209@discussion.autodesk.com...
Chris,
In my code "module1" is the name of the module I am gaining access to.
"test" is the name of the Sub within the Module. To reel this all in, what I
would do is create a userform (call it "MasterUserForm") that your master
module fires alone... on that userform use command buttons (yours would have
15 or as many as you want) to fire the other userforms. See a screen shot of
my userform (attached). My personal application loads this form, from here,
I pick a command button associated with what I want to manipulate (I
pictorially illustrated my command buttons). Once picked the command button
fires an additional userform that is more specific to the item chosen... So
in your case, you would replace "module1" with "Master" and test with
"MasterUserForm". In setting your code up this way you are better
streamlining the flow of information. In my case I have other users that do
not understand many things associated with IV. So in an attempt to make IV
more user friendly I have made it almost remedial...
Let me know how it turns out...
Bill
