Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
[VBA] Compart Local WorkAxes to Global WorkAxes
2 REPLIES 2
lemensk
804 Views, 2 Replies
I am trying to extract part locations from an assembly file.  I've been successful UNTIL I come to a part/subAssembly where the workAxes is orientated differently then the overall assembly axis.  Is it possible to compare the local axis to the global axis?  If the answer is 'yes', can sample code be posted (i.e. dim sameOrientation as bool; sameOrientation = ... )?
Also, once I know that "sameOrientation = false," how would one convert local coordinantes to global coordinates?
Thank you,
lemensk
2 REPLIES 2
Vladimir.Ananyev
in reply to: lemensk
The component position and orientation relative to the assembly coordinate system is defined by the matrix object that is returned by the ComponentOccurrence.Transformation property.
Hope the following links could help you to move in the right direction.
Examing the Matrix and other Inventor Math and Geometry Objects
http://modthemachine.typepad.com/files/mathgeometry.pdf
Occurrences, Contexts, Definitions, Proxies
http://adndevblog.typepad.com/manufacturing/2013/07/occurrences-contexts-definitions-proxies.html
Positioning Assembly Occurrences
http://modthemachine.typepad.com/my_weblog/2009/04/positioning-assembly-occurrences.html
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
lemensk
in reply to: Vladimir.Ananyev
Below is the answer to my question, each part is considerded to have the same axis.
'CODE START ---------------------------------
Sub printParts()
   Dim inventDoc As Inventor.AssemblyDocument
   Dim deltaX, deltaY, deltaZ, avgX, avgY, avgZ, minX, minY, minZ, maxX, maxY, maxZ As Double
   Dim fileName, strg As String
   Dim partOccur As Inventor.ComponentOccurrence
   Set inventDoc = ThisApplication.ActiveDocument
   fileName = inventDoc.DisplayName
   For Each partOccur In inventDoc.ComponentDefinition.Occurrences.AllLeafOccurrences   'For each part included in the assembly
       strg = partOccur.Name & ";" & partOccur.RangeBox.minPoint.X & ";" & partOccur.RangeBox.minPoint.Y & _
                 ";" & partOccur.RangeBox.minPoint.Z
      Open "C:\Temp\" & fileName & ".txt" For Append As #1 'Open txt file and Append
      Print #1, strg        'Print String
      Close #1        'Close txt file
   Next
End Sub
'CODE STOP ---------------------------------
