We have written some VBA code to insert custom properties into the iproperties for sheet metal components (Sheet blank area, component blank area and stock code number). This code has been working on our 32bit machines for several years.
We have recently upgraded two of our machines (the rest to follow shortly) to Windows XP 64bit, in doing so we have noticed that the VBA code does not work.
We have resolved the issue so that the code will now work with both 32bit and 64bit machines.
My question is; Can you mass replace the VBA code in all of our old drawings (that contain the old code) so that when opened with the new 64bit machines, the code will work and will update accordingly.
Note: i did not write this code and am a complete novice in VBA!
see attached for the old and new code - the bit that has changed is:
(old code) Set oFlatPattern = ThisDocument.ComponentDefinition.FlatPattern
(new code) ThisDocument.InventorDocument.InventorDocument.ComponentDefinition.FlatPattern
I hope this makes sense
Thanks in advance
Regards
Will
To update the VBA code to make it work for both x86 and x64 Inventors, you can use the
VBComponent.CodeModule.ReplaceLine to do this. But after you update the VBA code you should also
save the document, that means your old documents would be also migrated with current Inventor.
Below is a sample code that will update the ThisDocument in VBA code. You can copy it to a VB6
module, and add references to 'Microsoft Scripting Runtime', and 'Microsoft Visual Basic for
Applications Extensibility x.x'.
Sub Main() Dim oApp As Inventor.Application Set oApp = GetObject(, "Inventor.Application") oApp.Documents.CloseAll ' update all the documents' VBA code in below folder Dim sFolder As String sFolder = "C:\Mydrawings" Dim oFSO As New FileSystemObject Dim oFolder As Folder Set oFolder = oFSO.GetFolder(sFolder) Dim oFile As Scripting.file For Each oFile In oFolder.Files If Right(LCase(oFile.Name), 3) = "idw" Then ' open the drawing document Dim oDoc As PartDocument Set oDoc = oApp.Documents.Open(oFile.Path) Dim oProj As InventorVBAProject For Each oProj In ThisApplication.VBAProjects Debug.Print oProj.Name ' process the DocumentProject only If oProj.Name = "DocumentProject" Then Dim oComp As InventorVBAComponent For Each oComp In oProj.InventorVBAComponents Debug.Print oComp.Name ' process the ThisDocument module only If oComp.Name = "ThisDocument" Then Dim oVBComp As VBComponent Set oVBComp = oComp.VBComponent Dim oCodeModule As CodeModule Set oCodeModule = oVBComp.CodeModule If oCodeModule.Find("ThisDocument", 1, 1, oCodeModule.CountOfLines, Len(oCodeModule.Lines(oCodeModule.CountOfLines, oCodeModule.CountOfLines)), True) Then Dim sOldCode As String sOldCode = oCodeModule.Lines(1, oCodeModule.CountOfLines) Dim sUpdatedCode As String sUpdatedCode = Replace(sOldCode, "ThisDocument", "ThisDocument.InventorDocument") ' clear the module Call oCodeModule.DeleteLines(1, oCodeModule.CountOfLines) ' write the updated code Call oCodeModule.AddFromString(sUpdatedCode) ' save the change to the document oDoc.Save2 False End If End If Next End If Next End If ' close all the opened document(s) oApp.Documents.CloseAll Next End Sub
Hope this helps.
Hi
Thanks for the reply, This has solved my question (with a small mod to change to part files instead of idw's)
Many thanks
Will
