Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
VBA Check design doctor for errors in drawing
5 REPLIES 5
pball
1681 Views, 5 Replies
Is there a way to check in VBA if the design doctor has found errors in a drawing? I have a mass print script and it'd be handy to be able to skip printing any drawings that have errors like unatached dimensions and such.
5 REPLIES 5
philippe.leefsma
in reply to: pball
Hi There,
Take a look at the "ErrorManager Interface" in the help files, you can find samples there.
Public Sub ErrorManager()
    Dim errorMng As ErrorManager
    Set errorMng = ThisApplication.ErrorManager
    Dim errors As String
    errors = errorMng.AllMessages
End Sub
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
pball
in reply to: philippe.leefsma
Thanks for the help. This should help me do exactly what I want to do.
I tried this and all I get is <ErrorsAndWarnings/> even though I can see errors in the sketch doctor.  An suggestions?  Is there maybe a document error manager?
pball
in reply to: ChristiPedersen
The method above apparently can only pick up errors that happen while your code is running. If you just want to see if a document has an error or not there is a solution in a more recent thread of mine.
https://forums.autodesk.com/t5/inventor-customization/bug-with-checking-errormanager-with-vba/m-p/49...
ChristiPedersen
in reply to: pball
I read the thread.  Thank you so much.  I will test it.
