How do I access the PartDocument object belonging to the iPart Factory that generated a given iPart Member?
Is there a way to access the file name of the factory that generated an iPart Member?
Dim oModelMember As PartDocument Dim oModelFactory As PartDocument Set oModelMember = ThisApplication.Documents.Open("C:\Temp\Handholds\142 - HH Style 13\142-32-1995 HANDHOLD, STYLE 13R.ipt", False) Set oModelFactory = ThisApplication.Documents.Open("C:\Temp\Handholds\142 - HH Style 13.ipt", False)
I want to be able to open oModelFactory given oModelMember. I will be iterating through over a hundred different oModelMembers, so doing this manually would be tedious.
Any ideas?
Solved by JohanLarsson. Go to Solution.
I have not used iParts much and dont know if this is what you want to do:
Public Sub PartTest() Dim oPartDoc As PartDocument Set oPartDoc = ThisApplication.ActiveDocument MsgBox (oPartDoc.ReferencedDocumentDescriptors(1).FullDocumentName) End Sub
