Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Using iLogic/Rules with iParts and iAssembly
3 REPLIES 3
ASchlaack
413 Views, 3 Replies
I have many parts that all are iParts in and assembly. And they all have to change with eachother so the assembly itself is an iAssembly. When I change the iAssembly values so it changes the part it also changes the parts name on the parent child tree adding in a value.
In this case it added in "36" on the "LEFT_FRAME_LEG-SKIRT" and if i change the value in the table the value 36 will change along with it. This is where I run into my issue. I also need to use iLogic/Rules to suppress parts at times. but because the part names all change the rule losses what part it's related to. How can I get around this issue?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
3 REPLIES 3
mdavis22569
in reply to: ASchlaack
Would Level of Detail not work for you ....
Mike Davis
ASchlaack
in reply to: mdavis22569
In what way do you think I should use it?
Aaron Schlaack
rjay75
Override the names of the components in the assembly. Use that name to refer to the parts from iLogic.
