This seems like it should be easy, but I can't get the following piece of iLogic to run even with "Imports System.Linq" at the top:
'AddReference "System.Web" AddReference "System.Linq" Imports System.Linq Imports System.IO Imports System.Collections.Generic Sub Main() Call BeginCreateAssemblyStructure End Sub Sub BeginCreateAssemblyStructure 'define the parent assembly Dim asmDoc As AssemblyDocument asmDoc = ThisApplication.ActiveDocument Dim filename As String = System.IO.Path.GetFileNameWithoutExtension(ThisApplication.ActiveDocument.Displayname) Dim filetab As String = InputBox("Which project?", "4 Letter Project Code", "ABCD") + "-MODELLING-BASELINE" Dim PartsList As List(Of SubObjectCls) PartsList = New List(Of SubObjectCls) 'debug MessageBox.Show(PartsList.Count, "Parts List Count") Dim FilesArray As New ArrayList Dim tr As transaction tr = ThisApplication.TransactionManager.StartTransaction( _ ThisApplication.ActiveDocument, _ "Create Standard Parts From Excel") 'this is to simply set the excel values to the correct file/tab- nothing more! FileArray = GoExcel.CellValues("C:\VAULT WORKING FOLDER\Designs\Project Tracker.xlsx", filetab , "A3" , "A4") ' sets excel to the correct sheet! 'Data collection: For MyRow = 3 To 5000 ' max limit = 5000 rows for debugging purposes Dim SO As SubObjectCls SO = New SubObjectCls If GoExcel.CellValue("A"& MyRow) = "" Then Exit For SO.Partno = GoExcel.CellValue("B" & MyRow) SO.LegacyDescr = GoExcel.CellValue("K" & MyRow) SO.LegacyRev = GoExcel.CellValue("L" & MyRow) SO.LegacyDrawingNo = GoExcel.CellValue("M" & MyRow) SO.ParentAssembly = GoExcel.CellValue("I" & MyRow) PartsList.Add(SO) Next MessageBox.Show(PartsList.Count, "Parts List Count") 'sort our list of parts PartsList.Sort() Dim r = From a As SubObjectCls In PartsList Where a.PartNo.StartsWith("AS-") And a.ParentAssembly = filename Select a '<-- ERROR IS AT THIS LINE For i = 0 To r.Count -1 MessageBox.Show(r(i).PartNo + vbCrLf + r(i).ParentAssembly,"Info in part #" + i.ToString()) Next i For i = 0 To PartsList.Count - 1 'MessageBox.Show(PartsList(i).PartNo,"Part No in part: " + i.ToString()) Next End Sub Public Class SubObjectCls Public PartNo As String Public LegacyDescr As String Public LegacyRev As String Public LegacyDrawingNo As String Public ParentAssembly As String Public Sub Init(m_partno As String, m_legacydescr As String, m_legacyrev As String, m_legacydrawingno As String, m_parentassy As String) PartNo = m_partno LegacyDescr = m_legacydescr LegacyRev = m_legacyrev LegacyDrawingNo = m_legacydrawingno ParentAssembly = m_parentassy End Sub End Class
Does anyone have any ideas why this isn't working? (The error message I receive is:
"Error on Line 64 : Expression of type 'System.Collections.Generic.List(Of LmiRuleScript.SubObjectCls)' is not queryable. Make sure you are not missing an assembly reference and/or namespace import for the LINQ provider."
Alex.
Solved by philippe.leefsma. Go to Solution.
Hi Alex,
Try that: http://msdn.microsoft.com/en-us/library/bb763092.aspx
Philippe.
Hi Philippe,
That's the exact same link I ended up at yesterday- I have now added a "CompareTo" function to my class so that it now looks like this:
Public Class SubObjectCls Implements IComparable(Of SubObjectCls) Public PartNo As String Public LegacyDescr As String Public LegacyRev As String Public LegacyDrawingNo As String Public ParentAssembly As String Public HasChildren As Boolean Public Children As List(Of SubObjectCls) Public Sub Init(m_partno As String, m_legacydescr As String, m_legacyrev As String, m_legacydrawingno As String, m_parentassy As String, m_haschildren As Boolean, m_children As List(Of SubObjectCls)) PartNo = m_partno LegacyDescr = m_legacydescr LegacyRev = m_legacyrev LegacyDrawingNo = m_legacydrawingno ParentAssembly = m_parentassy HasChildren = m_haschildren Children = m_children End Sub Public Function CompareTo(other As SubObjectCls) As Integer Implements IComparable(Of SubObjectCls).CompareTo Return Me.CompareTo(other) End Function End Class
And Linq is quite happy doing it's stuff.
That's not to say of course that my iLogic subroutine is working how I'd like however- I still have a few bugs to iron out with creating sub-assemblies/parts...
I will update the other post I made yesterday when I have something that works 100% of the time using the above class.
