Using Linq with Inventor iLogic
2 REPLIES 2
AlexFielder
898 Views, 2 Replies
This seems like it should be easy, but I can't get the following piece of iLogic to run even with "Imports System.Linq" at the top:
'AddReference "System.Web"
AddReference "System.Linq"
Imports System.Linq
Imports System.IO
Imports System.Collections.Generic
Sub Main()
Call BeginCreateAssemblyStructure
End Sub
Sub BeginCreateAssemblyStructure
'define the parent assembly
Dim asmDoc As AssemblyDocument
asmDoc = ThisApplication.ActiveDocument
Dim filename As String = System.IO.Path.GetFileNameWithoutExtension(ThisApplication.ActiveDocument.Displayname)
Dim filetab As String = InputBox("Which project?", "4 Letter Project Code", "ABCD") + "-MODELLING-BASELINE"
Dim PartsList As List(Of SubObjectCls)
PartsList = New List(Of SubObjectCls)
'debug
MessageBox.Show(PartsList.Count, "Parts List Count")
Dim FilesArray As New ArrayList
Dim tr As transaction
tr = ThisApplication.TransactionManager.StartTransaction( _
    ThisApplication.ActiveDocument, _
    "Create Standard Parts From Excel")
'this is to simply set the excel values to the correct file/tab- nothing more!
FileArray = GoExcel.CellValues("C:\VAULT WORKING FOLDER\Designs\Project Tracker.xlsx", filetab , "A3" , "A4") ' sets excel to the correct sheet!
'Data collection:
For MyRow = 3 To 5000 ' max limit = 5000 rows for debugging purposes
	Dim SO As SubObjectCls
	SO = New SubObjectCls
	If GoExcel.CellValue("A"& MyRow) = "" Then Exit For
	SO.Partno = GoExcel.CellValue("B" & MyRow)
	SO.LegacyDescr = GoExcel.CellValue("K" & MyRow)
	SO.LegacyRev = GoExcel.CellValue("L" & MyRow)
	SO.LegacyDrawingNo = GoExcel.CellValue("M" & MyRow)
	SO.ParentAssembly = GoExcel.CellValue("I" & MyRow)
	PartsList.Add(SO)
Next
'sort our list of parts
PartsList.Sort()
Dim r = From a As SubObjectCls In PartsList Where a.PartNo.StartsWith("AS-") And a.ParentAssembly = filename Select a '<-- ERROR IS AT THIS LINE
For i = 0 To r.Count -1
	MessageBox.Show(r(i).PartNo + vbCrLf + r(i).ParentAssembly,"Info in part #" + i.ToString())
Next i
For i = 0 To PartsList.Count - 1
	'MessageBox.Show(PartsList(i).PartNo,"Part No in part: " + i.ToString())
Next
End Sub
Public Class SubObjectCls
	Public PartNo As String
	Public LegacyDescr As String
	Public LegacyRev As String
	Public LegacyDrawingNo As String
	Public ParentAssembly As String
	Public Sub Init(m_partno As String,
					m_legacydescr As String,
					m_legacyrev As String,
					m_legacydrawingno As String,
					m_parentassy As String)
		PartNo = m_partno
		LegacyDescr = m_legacydescr
		LegacyRev = m_legacyrev
		LegacyDrawingNo = m_legacydrawingno
		ParentAssembly = m_parentassy
	End Sub
End Class
 Does anyone have any ideas why this isn't working? (The error message I receive is:
"Error on Line 64 : Expression of type 'System.Collections.Generic.List(Of LmiRuleScript.SubObjectCls)' is not queryable. Make sure you are not missing an assembly reference and/or namespace import for the LINQ provider."
Alex.
Tags (2)
2 REPLIES 2
Hi Alex,
Try that: http://msdn.microsoft.com/en-us/library/bb763092.aspx
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Hi Philippe,
That's the exact same link I ended up at yesterday- I have now added a "CompareTo" function to my class so that it now looks like this:
        Implements IComparable(Of SubObjectCls)
        Public HasChildren As Boolean
        Public Children As List(Of SubObjectCls)
                        m_parentassy As String,
                        m_haschildren As Boolean,
                        m_children As List(Of SubObjectCls))
            PartNo = m_partno
            HasChildren = m_haschildren
            Children = m_children
        End Sub
        Public Function CompareTo(other As SubObjectCls) As Integer Implements IComparable(Of SubObjectCls).CompareTo
            Return Me.CompareTo(other)
        End Function
    End Class
 And Linq is quite happy doing it's stuff.
That's not to say of course that my iLogic subroutine is working how I'd like however- I still have a few bugs to iron out with creating sub-assemblies/parts...
I will update the other post I made yesterday when I have something that works 100% of the time using the above class.
