tmpApp.UnitsOfMeasure.GetStringFromType(Inventor.UnitsTypeEnum.kCentimeterLengthUnits)
returns "zentimeter"
Is there also a function which returns the unit sign "cm" ???
Stephan
Solved by Mike.Wohletz. Go to Solution.
Solved by JohanLarsson. Go to Solution.
no suggestions on this case ???
My addin writes a list of dimensions with the unit sign to a csv file and it would really be helpful if I could use a Inventor mechanism instead of translating them manually.
Thanks, Stephan
Depending on what you want to do this might be good enough but it sure is not pretty:
Private Sub test() s = GetUnitString(kCentimeterLengthUnits) End Sub Public Function GetUnitString(oEnum As UnitsTypeEnum) As String oEnum = kCentimeterLengthUnits s = ThisApplication.UnitsOfMeasure.GetLocaleCorrectedExpression("1", oEnum) GetUnitString = Mid(s, 3) End Function
This is how I get it, this uses the document units. The only real difference from what was posted is that trimming off x number of characters will cause issues when document units change and causes decimals to be inserted.
Private Sub Button2_Click(sender As System.Object, e As System.EventArgs) Handles Button2.Click MsgBox(GetUomLabel(ThisApplication.ActiveEditDocument.UnitsOfMeasure)) End Sub Public Function GetUomLabel(ByVal DocumentUnits As UnitsOfMeasure) As String Dim StrUnits As String = ThisApplication.UnitsOfMeasure.GetStringFromValue(1, DocumentUnits.LengthUnits) Return StrUnits.Remove(0, StrUnits.LastIndexOf(" ")) End Function
