Inventor Customization
Member
rrdeveloper
Message 1 of 5 (626 Views)
Turn off Translucent using VBA
626 Views, 4 Replies
11-10-2011 08:36 PM
Hi All,
I'm trying to make a translucent part file to a opaque part file by using the below code
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    oDocument.ActiveRenderStyle.Opacity = 1    'making the body opaque
But it doesnot help.Can someone please let me know how to do it through code.
PS: attached is the process of doing it manually
Thank You
Valued Mentor
JohanLarsson
Message 2 of 5 (615 Views)
Re: Turn off Translucent using VBA
11-12-2011 07:19 AM in reply to: rrdeveloper
Like this?
Public Sub TranslucentTest()
    Dim app As Inventor.Application
    Set app = ThisApplication
    Dim partDoc As PartDocument
    Set partDoc = app.ActiveDocument
    Dim oWorkSurface As WorkSurface
    Set oWorkSurface = partDoc.ComponentDefinition.WorkSurfaces.Item(1)
    oWorkSurface.Translucent = False
End Sub
Inventor Professional 2012 SP1 (25 seats with subscription)
Windows 7 64 bit
Lenovo D20, 12 GB RAM, Intel Xeon X5687 3.6 GHz, SSD
Quadro 4000, driver 8.17.12.9573, dual monitors
SpacePilot, driver version 6.15.3 Firmware 3.12
Member
rrdeveloper
Message 3 of 5 (604 Views)
11-13-2011 07:40 PM in reply to: JohanLarsson
Thank You.
I works as expected :womanvery-happy:
Active Member
jalexander
Message 4 of 5 (539 Views)
03-14-2012 07:40 AM in reply to: JohanLarsson
This works for part docs only, is there any way we can improve upon this to change all part surfaces in an assembly file instead of opening each part that has a surface individually?
Member
rrdeveloper
Message 5 of 5 (526 Views)
03-14-2012 08:47 PM in reply to: jalexander
        Dim oModel As AssemblyDocument
        Set oModel = ThisApplication.ActiveDocument '.iam file
        'or open the assembly file as below
        'Set oModel = ThisApplication.Documents.Open("D:\TestAssm.iam", False)
       'then identify each part in the assembly & set the surface to opaque
      For i = 1 To oModel.ComponentDefinition.Occurrences.Count
       Set partDoc = oModel.ComponentDefinition.Occurrences.Item(i).Definition.Document
       Next
End Sub
The above code identifies each part in the assembly & changes its surface
Hope this helps
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
