I'm struggling a little with editing strings in iLogic. I have sets of part numbers that vary in length, but I'd like the part number to appear in another custom property with the last 6 characters trimmed off.
e.g.
Part Numbers: 12345_WXXXX
123456789_WXXXX
123_WXXXX
Desired Values in custom feild: 12345
123456789
123
I can write a line of code that keeps the last 6 characters but I can't get it to trim off the last six, because I don't know how many characters will be in the code before the last 6.
Hope it's something simple.
Thanks in advance
GavoGarmo
Solved by thomaskennedy. Go to Solution.
I've worked out a work around but I'm sure there must be a better way of doing it:
iProperties.Value("Project","Part Number") = "ABCDEFGHIJ_WXXX" iProperties.Value("Custom","REVNUM") = StrReverse(iProperties.Value("Project","Part Number")) iProperties.Value("Custom","REVNUMTRIM") = Mid(iProperties.Value("Custom","REVNUM"),6,20) iProperties.Value("Project","Stock Number") = StrReverse(iProperties.Value("Custom","REVNUMTRIM"))
Solved it with a bit of net searching:
In my case the "_" will always be there, so not quite a solution that will work for everyone but it might help someone.
If any one knows how to cut off the last 6 characters, no matter what charaters are used, I'd be really interested.
iProperties.Value("Project","Stock Number") = iProperties.Value("Project","Part Number").Substring(0,iProperties.Value("Project","Part Number").IndexOf("_"))
You could use the Mid() function, but pass in the length of the string - 6 like this :
Mid(iProperties.Value("Project","Part Number"),1,Len(iProperties.Value("Project","Part Number"))-6)
Tom
Awesome! I like that a lot more than looking for the "_"
Thanks very much!
