I have a iLogic assembly that has User Parameters driving the subassemblies.
When using event triggers,
Changes to the User Parmaters will not trigger the rule unless model parameters actually change a sketch or WorkPlane when using any model parameter change.
Changes to the User Parmeters will not trigger the rule when using the parmeter in the iProperties and Trigger is on iProperty Change.
Is there a work around to trigger a rule based on User Parmeters change?
(I could make a sketch using all the parameters and keep it hidden but, that is not the best)
OK, I used an iTrigger parameter and had it equal to the sum of all user parameters. One long equation.
First line in the code is
trigger = iTrigger0
