hello
I have a rule in part, to scale automatically when the file is opened.
I am encountering error when performing the thread in the rule.
in line to apply the new thread, the following error appears:
Sub Main() If DI>=DE Then MessageBox.Show("Diametro Interno NaO pode ser superior ao Externo", "Title") Return End If Parameter("diam_ext") = DE Parameter("diam_int") = DI Parameter("compr") = L If temrosca = "TRUE" Then Feature.IsActive("Rosca_Graxeira")="True" Feature.IsActive("Furo_grax")="True" Feature.IsActive("Chanfro_rosca")="True" If rosca = "1/8 BSP" Then diam_rosca = "8.8" Feature.SetThread("Rosca_Graxeira", "BSP Pipe Threads", "G 1/8-28", "") ElseIf rosca = "1/8 GAS" Then diam_rosca = "8.55" Feature.SetThread("Rosca_Graxeira", "BSP Pipe Threads", "G 1/8-28", "") ElseIf rosca = "1/8 NPT" Then diam_rosca = "8.70" Feature.SetThread("Rosca_Graxeira", "NPT", "1/8 -27NPT", "") ElseIf rosca = "3/8 BSP" Then diam_rosca = "15.3" Feature.SetThread("Rosca_Graxeira", "BSP Pipe Threads", "G 3/8-19", "") ElseIf rosca = "M10 x 1" Then diam_rosca = "9" Feature.SetThread("Rosca_Graxeira", "ANSI Metric M Profile", "M10x1", "6H") ElseIf rosca = "M6 x 1" Then diam_rosca = "5" Feature.SetThread("Rosca_Graxeira", "ANSI Metric M Profile", "M6x1", "6H") ElseIf rosca = "M8 x 1" Then diam_rosca = "7" Feature.SetThread("Rosca_Graxeira", "ANSI Metric M Profile", "M8x1", "6H") ElseIf rosca = "M8 x 1,25" Then diam_rosca = "7.75" Feature.SetThread("Rosca_Graxeira", "ANSI Metric M Profile", "M8x1.25", "6H") End If Parameter.UpdateAfterChange = True Else Feature.IsActive("Rosca_Graxeira")="False" Feature.IsActive("Furo_grax")="False" Feature.IsActive("Chanfro_rosca")="False" Return End If Return End Sub
Try removing the "8.8" from the dimension assignment.
diam_rosca = 8.8
etc.
