Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Talking to Inventor: Wait!
25 REPLIES 25
Message 1 of 26
1823 Views, 25 Replies
I'm working on a replace program from the VBA editor. What I'm trying to do now is tie this all together. A set of files is renamed. That part is most of my program. From there, it allows you to select your assembly using an open file dialog and click open. When you open it it uses a silent operation to skip the "Oh no! I lost your files!" box. Now I'm on my link resolve issue.
So what I have is say, a couple files named:
UglyPonies-001.ipt
UglyPonies-002.ipt
UglyPonies-003.ipt
I've now renamed them to:
PrettyPonies-001.ipt
PrettyPonies-002.ipt
PrettyPonies-003.ipt
and I've opened up:
PrettyPonies-004.iam
To identify these files, I have two modules called OldNameiLoop and NewNameiLoop. It concatenates a file path adding on a suffix and adding one to it each time. Originally I had a MsgBox set up to display this file name, but I've now deleted it. I will post the codes below. So what I'm trying to do now is basically tell Inventor to replace the component OldNamePath with NewNamePath and then add i + 1 to the prefix name and do that same with that path. Anyone have any idea of how to tell Inventor to do that?
OldNameiLoop:
Option Explicit
    Public Sub OldNameiLoop()
    Dim i As Double
    Dim NameStr2 As String
    Dim OldNamePath As String
    NameStr2 = Renamer.Old_Name_Display.Text
    OldNamePath = NameStr & "-" & Right("00" & i, 3) & ".ipt"
    Do While i < 99
    i = i + 1
        If 'Something Happens Here' Then
        '3-character string created by using the Right() function
    Next i
        Else: Exit Sub
    Loop
    End Sub
NewNameiLoop:
Option Explicit
    Public Function NewNameiLoop()
    Dim i As Double
    Dim NameStr As String
    Dim NewNamePath As String
    NameStr = Renamer.New_Name.Text
    NewNamePath = Renamer.Path_Text.Text & "\" + NameStr & "-" & Right("00" & i, 3) & ".ipt"
    Do While i < 99                               'Counts with the file name up to -099
    i = i + 1
        If 'Something happens here' Then
    Loop
        Else: Exit Function
    End Function
 ReplaceComponent:
Option Explicit
    Public Function ReplaceComponent()
    Dim oOccurrence As ComponentOccurrence
    Set oOccurrence = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.OldNamePath
    oOccurrence.Replace NewNamePath, True
    End Function
 This all links to UserForm3 when the user clicks "Open":
Private Sub Open_Button_Click()
    ThisApplication.SilentOperation = True                'Suppresses the resolve links dialog
    Dim myPath As String
    myPath = FileName.Text                                              'Gets the string, FileName, from module 1
    Dim Shell As Object
    Set Shell = CreateObject("Shell.Application")
    Shell.Open (myPath)                                                      'Opens selected file
    Resolve_and_Open.Hide                                               'Hides module
    ReplaceComponent
End Sub
25 REPLIES 25
Message 21 of 26
I am going to post my code in case anyone has any ideas and would like to try them. Here is the .ivb, attached. I left the Module in question as "Module1"
Message 22 of 26
DeerSpotter
John Hurt (War Doctor) - Doctor Who, my gf's fav show. 😉 you picked the right quote.
Image and video hosting by TinyPic
See My LinkedIn Profile
Message 23 of 26
in reply to: DeerSpotter
I thought so 🙂 Love that show
Message 24 of 26
I think I'm going to move this to a new thread. It doesn't make much sense here anymore
Message 25 of 26
adam.nagy
You're planning to continue this in a "Doctor Who" thread? 😉
I've looked at the code and the problem seems to be that there is no ActiveDocument at the moment of the ReplaceReference function being called.
I only provided that code to give an idea about what to do.
You probably know better the logic of your application, but basically you would need to open up the assembly file:
    Dim doc As Document
    Set doc = ThisApplication.Documents.Open(Resolve_and_Open.FileName, False) ' you can open it invisible too
   Do While i < 99
    Dim f As File
    'Set f = ThisApplication.ActiveDocument.File
    Set f = doc.File
    Dim fd As FileDescriptor
    For Each fd In f.ReferencedFileDescriptors
        If fd.FullFileName = OldNamePath Then
            fd.ReplaceReference (NewNamePath)
        Next
    Loop
    doc.Save
    doc.Close
Cheers,
Adam Nagy
Autodesk Platform Services
Message 26 of 26
in reply to: adam.nagy
Hahaha not so sure I do know the logic of my own code. I'm so new to this, it's a wonder I've made it this far in the program.
That is indeed the problem. I've been working with rjay in this thread on that. He's recommending I basically change the workflow of the whole code. I would really rather not since I've been working on this for two months and would hate to scrap it, but I guess it happens sometimes.
Really the only problem left is that it isn't recognizing this line in his suggested code:
fd.ReplaceReference (NewFileName)
 So that's unfortunate. I think the whole thing would work if that one line would work. Oh, the woes of VBA.
