Are you guys sure you want to be in the VBA customization NG?
The fonts it uses are amgdt and aigdt. (it actually appears to be using the aigdt) don't
know how to make the dropdown change other than doing the characters manually.
For the note balloon make a sketched symbol.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Nick Ruberg" wrote in message
news:3F99DBA7B7FEBAC5E5D10AD0B0579899@in.WebX.maYIadrTaRb...
> I have the same problem. The font I use for dimensioning is the ISOCP font which looks
like a stencil font and is also thin enough that it does not detract the reader from the
details of the drawing. Whenever I use anything with a symbol, such as diameter or
degrees, it uses the AIGDT font which is very dark. The interesting thing is that all of
those symbols are present in the ISOCP font. It is possible to use them by the correct
Alt-key combinations or with character generator in a different program like MS Word. I
simply cannot find anywhere in Inventor where we can choose the font for the symbols.
> I eagerly watch this thread in the hope someone will solve this mystery.
> "kckoons" wrote in message news:f0e31d5.-1@WebX.maYIadrTaRb...
> In .idw files that I create in Inventor 5.3. Symbols such as the diameter symbol and
the symbols within the feature control frame print very dark. RomanS is the text font that
my company uses as it's standard and it prints much lighter than the symbols. I have tried
bolding the text and this helps some but not nearly enough. Also, I can't find a note
baloon (a number within a triangle) anywhere in Inventor. Does anyone know if there is
one. Thanks.
