Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Suppressing components based on part of their name
6 REPLIES 6
andrewiv
668 Views, 6 Replies
I'm working on a piece of iLogic code that supresses components in an assembly base on selections made to an excel sheet.  To do this I'm using Case statements.  The problem is that the display name of the components has the part number in it and I want to be able to use this code on multiple assemblies with different parts in them.  So I want to be able to suppress component based on if their name contains a string.  Here is a sample of my code.
Select Case DRIVE
      Case "0"
             Component.IsActive("226343:1-DRIVE 460V")=0
             Component.IsActive("236662:1-DRIVE 380V")=0
             Component.IsActive("289132:1-DRIVE 575V")=0
      Case "1"
             Component.IsActive("226343:1-DRIVE 460V")=1
      Case "2"
             Component.IsActive("236662:1-DRIVE 380V")=1
      Case "3"
             Component.IsActive("289132:1-DRIVE 575V")=1
End Select
So basically I want to remove the part numbers from what I've got shown and suppress or unsuppress based on the 460V, 380V, and 575V string.  Does anyone know how to do this?
Andrew In’t Veld
Designer
6 REPLIES 6
Hi andrewiv,
You can use String.Contains() to do this. Here is a real quick example that looks at all of the components in an assembly and finds the ones that contain a defined string value.
I didn't have time to stop to look at your Select Case code to see how this would tie into what you have, but you should be able to work it out. If not post back and I'm sure someone will take another look.
Related links:
http://msdn.microsoft.com/en-us/library/dy85x1sa%28v=vs.110%29.aspx?cs-save-lang=1&cs-lang=vb#code-s...
http://stackoverflow.com/questions/6370081/vb-net-if-string-contains-value1-or-value2
I hope this helps.
Curtis
' set a reference to the assembly component definintion.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim myString1 As String = "380V"
Dim myString2 As String = "460V"
Dim myString3 As String = "575V"
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
    If oOccurrence.Name.Contains(myString1) Or _
    oOccurrence.Name.Contains(myString2) Or _
    oOccurrence.Name.Contains(myString3) Then
    'Show occurrence name in the message
    MessageBox.Show("Suppressing: " & oOccurrence.Name, "iLogic")
    'suppress the component
    Component.IsActive(oOccurrence.Name) = False
    Else
    End If
Next
Thanks for the help.  I think I got it now.  I changed my program to read like this.
Dim doc As AssemblyDocument
Dim oComp As ComponentOccurrence
Dim oComps As ComponentOccurrences
doc = ThisDoc.Document
oAsmCompDef = doc.ComponentDefinition
oComps = oAsmCompDef.Occurrences
For Each oComp In oComps
	If oComp.Name.Contains("DRIVE 460V") Then
		DRIVE460V = oComp.Name
	ElseIf oComp.Name.Contains("DRIVE 380V") Then
		DRIVE380V = oComp.Name
	ElseIf oComp.Name.Contains("DRIVE 575V") Then
		DRIVE575V = oComp.Name
	End If
Next
Select Case DRIVE
	Case "0"
		Component.IsActive(DRIVE460V)=0
		Component.IsActive(DRIVE380V)=0
		Component.IsActive(DRIVE575V)=0
	Case "1"
		Component.IsActive(DRIVE460V)=1
	Case "2"
		Component.IsActive(DRIVE380V)=1
	Case "3"
		Component.IsActive(DRIVE575V)=1
End Select
Andrew In’t Veld
Designer
This code works for me as well, but how can I also suppress constraints containing the same string of text?
This code works for me as well, but how can I adjust the code to suppress constraints containing a string of text (rather than or in addition to files)?
...and component patterns?
Hi @Curtis_Waguespack  is it possible to use above code with below condition instead of the below hard way one by on to suppress based on name " INNER" , thanks.
