Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
SubOccurrences property throw COMException
4 REPLIES 4
FRFR1426
531 Views, 4 Replies
When trying to loop on sub occurrences, on some assemblies, the property SubOccurences thow a COMException:
System.Runtime.InteropServices.COMException (0x80004005): Erreur non spécifiée (Exception de HRESULT : 0x80004005 (E_FAIL))
   à System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   à Inventor.ComponentOccurrence.get_SubOccurrences()
What can cause this type of error?
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
4 REPLIES 4
YuhanZhang
in reply to: FRFR1426
Can you upload the data that can reproduce this problem? And which Inventor version you are using?
Please don't upload confidential data.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
FRFR1426
in reply to: YuhanZhang
The problem occurs on Inventor Suite 2011 SP2 (Build 150309200, 309). I will upload some data, but via ADN DevHelp because the data is confidential (when it will work, which is not the case right now. I can not connect Smiley Frustrated)
Maxence DELANNOY
Manager
http://wiip.fr
nagwani
Hi There,
I had similar issue once, and I found that if your are not in Master LOD and some of the occurrences have been suppresses then getting SubOccurrences from suppressed Occurrence would fail.
-Ishwar N
FRFR1426
in reply to: nagwani
Found it! I have to test the property Suppressed before accessing to the property SubOccurences.
Maxence DELANNOY
Manager
http://wiip.fr
