Just so I don't reinvent the wheel, is there a function which returns the currently open document type as a string, something like this:
const char* const GetInventorDocTypeDesc(DocumentTypeEnum eDocTypeEnum);
? If you see what I mean. Any sort of string will be fine.
Solved by oransen. Go to Solution.
I've written my own:
typedef struct { DocumentTypeEnum eEnum ; const char* const pszDesc ; } DocDesc_t; const DocDesc_t kDocDescs [] = { {kAssemblyDocumentObject, "Assembly Document"}, {kDesignElementDocumentObject, "Design Element Document"}, {kDrawingDocumentObject, "Drawing Document"}, {kForeignModelDocumentObject, "Foreign Model Document"}, {kNoDocument, "No Document"}, {kPartDocumentObject, "Part Document"}, {kPresentationDocumentObject, "Presentation Document"}, {kSATFileDocumentObject, "SAT File Document"}, {kUnknownDocumentObject, "Unknown Document"} } ; static const UINT ikNumDocTypeDescs = sizeof (kDocDescs)/sizeof(kDocDescs[0]) ; const char* const GetInventorDocTypeDesc(const DocumentTypeEnum eDocTypeEnum) { for (UINT i = 0 ; i < ikNumDocTypeDescs ; i++) { if (kDocDescs[i].eEnum == eDocTypeEnum) { return kDocDescs[i].pszDesc ; } } // This is an error, I handle it recursively... return (GetInventorDocTypeDesc(kUnknownDocumentObject)) ; }
