Hello everone,
I've a simple problem that is to be solved on Inventor.
I've a customer component for which a fixture has to be designed which holds the component rigidly and in Equilibrium.
e.g. A block that is supported by pillars at random location. How do I know that this setup is in equilibrium and the component is resting on the pillars in equilibrium.
Kindly support!
Thanks & Regards,
Arjun koti.
