Hi, Jaan
It is the operating system rather than design assistant causing the sounds.
You can turn the sounds off in following two ways:
<1> Change the theme for OS;
<2> In Vista: Control Panel > Sounds(class view) > Sounds tab, change the
'sound scheme' to 'No Sounds' > OK
You can do the similar process in other OS if necessary.
Hope it help! : )
Jimmy Yuan
"Jaan17" wrote in message news:5928256@discussion.autodesk.com...
Hi all,
I have searched everywhere for a way to turn the annoying 'bleep' and 'beep'
sounds off when modifying, opening files etc in design assistant. Searched
the entire Inventor folder on my hdd for any .wav files etc and all I can
find is the constraint.wav file!
I listen to music through headphones whilst working and it is driving me
crazy!
Any help would be greatly appreciated!
Kind Regards,
Jaan
