A while ago I needed to get in ilogic the volume of a body from a multibody part. Here is the solution: http://forums.autodesk.com/t5/Autodesk-Inventor/Body-Volume-to-be-assigned-to-a-parameter/td-p/36347...
Now I need the mass of a body. I'm not sure it's possible to use the same base rule "SolidFunctions".
Please help me if you know how.
Regards
Alexandru
Could this discussion help?
ipt: how to get mass of one solid
Cheers,
