SketchBlock Position
1 REPLY 1
324 Views, 1 Reply
I have a sketchblock in a sketch that I need to postion into the correct quadrant. I have dimensions on the sketchblock that are told to be driven while running the quadrant position task shown below. see image. Sketchblock is currently in quadrant 1 and I need to be able to push that into the 3rd, thus the (-200,-200).
ThisApplication.ActiveDocument.ComponentDefinition.Sketches(1).SketchBlocks.Item(1).Postion.X = -200
ThisApplication.ActiveDocument.ComponentDefinition.Sketches(1).SketchBlocks.Item(1).Postion.Y = -200
After it is in the correct quadrant I power the dimensions to constraint the sketchblock into correct position.
The question is, how do I position the sketchblock in the correct quadrant via 'position'?
Not working.
1 REPLY 1
Vladimir.Ananyev
This method works in your case:
Sub MoveBlock()
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oDef As PartComponentDefinition
  Set oDef = oDoc.ComponentDefinition
  Dim oSketch As Sketch
  Set oSketch = oDef.Sketches.Item(1)
  Dim oBlock As SketchBlock
  Set oBlock = oSketch.SketchBlocks.Item(1)
  Dim oP As Point2d
  Set oP = oBlock.Position
  oP.x = oP.x + 1
  oP.y = oP.y + 1
  oBlock.Position = oP
  oSketch.Solve
End Sub
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
