Hello guys,
I'm tried put a cutomized image in my macro button, but I can't.
In the same location of my default DVB file, I put the file .BMP:
In this case:
or
Please, look the attached file and see with your eyes, if I'm doing something wrong.
Thank you!!!
Solved by YuhanZhang. Go to Solution.
Can you double check below info:
1. You created the small icon with 16X6 and large icon with 32X32 pixels size? Other sizes may not work for Inventor macros.
2. You have to re-launch Inventor after placing the icons, so Inventor can associate them with macros.
Brian posted an article for this, please refer to:
http://modthemachine.typepad.com/my_weblog/2008/11/creating-buttons-for-vba-macros.html
Hope this helps.
Thanks Rocky,
I have read all this article in Mod the Machine.
Step by step again.
I made new Icons, one of them, Large and other Small.
Start and Re-start Inventor.
But the Icon in the Button appears the same every time. Like a Visual Studio Symbol.
I Attached the two Icons for you see.
Any ideias or concerns will be welcome.
Thanks.
Dear Rocky,
Just re-start the Inventor not works. But when I re-start the machine, the Icon appears as well.
Thank you!!!
I'm having a similar problem in IV2013. My macro button images USED to work in 2012. Now, when I try to set one of the buttons to the large image, I get an orange colored "@" symbol instead. I tried re-scaling the large icon bitmaps to 32x32 (used to be 24x24?), Rebooting, etc. Does anyone know what this "@" symbol is supposedly telling me?
come on! autodesk THIS IS A BUG!!! NEVER FIX IT! IT IS AUTODESK INVENTOR 2014!! NO FIX!!!
This is a known issue to us that large icon for a VBA macro could not be displayed on ribbon, but it is not addressed in Inventor 2014 yet, sorry for that. Please provide 1463005 to us to check the status of the issue, or report this to ADN to ask a hotfix if possible.
Yes the large icon is 32x32 now, you can find the document from(Add a macro to a User defined panel on the ribbon):
Unfortunately there is a defect for VBA macro large icon and was reported to us, you can provide 1463005 to check its status to us. The small icon still works for VBA macro. The "@" icon is a general icon when the user defined icon could not be loaded.
Is there any status report on this bug (1463005)
Where can I request a status report for this bug?
The defect is not closed because we can't reproduce it in Inventor 2014 SP1, if you have upgraded your Inventor to 2014 SP1 please double check it.
SP1 is out sinds this morning.
In the release notes it you can read the following:
Summary of Issues Fixed by this Service Pack:
Application Functionality
I installed SP1 and I can confirm that the issue is fixed. The bug can thus be closed.
Thanks for the quick reply
Klaas De Smedt
