It would register in the add-ins, but wouldn't actually update the parameter values. However, I messed around with ilogic and actually got a very simple two lines of code to do what I needed. Thanks for the reply.
@ekinsb wrote:
Sorry for the delay in responding. I have found a problem. Attached is a new installer. It will install the add-in along with a zip file that contains the source code. Let me know if there are any problems running it.
I have upgraded from 2013 to 2015. This was working in 2013... but now it does not update the parameters. I ran the installer (the one posted in message 77 above) and it still does not work. Before running the installer, I removed the files from the %appdata% folder, then ran the installer.
After I ran the installer, I did check the %appdata%\Autodesk\ApplicationPlugins\SheetMetalExtents folder and the .addin and the .dll is there... and the addin appears in the Inventor Add-ins manager (is also loaded). It just does not write the values in the paramaters when I save my sheetmetal part.
Any suggestions from anyone using 2015 on getting this to work?
Kirk
The code works great for new sheet metal parts, but I cannot get it generate the data for existing parts. How is this done?
Thanks.
