Well I don't remember where the post was from last time, but I did download it from here and then rebuild it again with .NET 3.5 and also updated to the 2012 reference and it all came back what the real problem may have been before. When I updated the reference I had two errors with the following lines;
If Math.Abs(invFlatPattern.Length - invLengthParameter.Value) > 0.0000001 Then invLengthParameter.Value = invFlatPattern.Length madeChange = True End If If Math.Abs(invFlatPattern.Width - invWidthParameter.Value) > 0.0000001 Then invWidthParameter.Value = invFlatPattern.Width madeChange = True End If
I have changed this to be as follows;
If Math.Abs(invFlatPattern.Length - CType(invLengthParameter.Value, Double)) > 0.0000001 Then invLengthParameter.Value = invFlatPattern.Length madeChange = True End If If Math.Abs(invFlatPattern.Width - CType(invWidthParameter.Value, Double)) > 0.0000001 Then invWidthParameter.Value = invFlatPattern.Width madeChange = True End If
The conversion of the object to type Double got rid of the error and I think it should now work in 2013.
The attached was not tested so please let me know if you have any errors.
Rob,
In the meantime, I opened the zip that Mike posted. In it is a SheetMetalExtents.dll. I overwrote the .dll that was on my hard drive with this one.
That got me going again in 2013.
Kirk
Thanks Kirk. I hope to be installing 2013 in the next week or so. I will do the same as you until I have Brian's updated program. Thanks to Mike as well.
Rob
I've updated the program. You can find more info and the update here:
http://modthemachine.typepad.com/my_weblog/2012/05/sheet-metal-extents-add-in-update.html
Hi I was able to get the 'Mike' version of this program running on 2013.
At first when I ran the ..64.bat I got an error with something to do with the codebase switch.
I just edited the .bat file and removed the switch and it seems like it is working so far...
Just want to know if this is ok??
For what ever reason I could not get the 'Brian' version to work...I tried the supplied installer, as well as ensuring the files were copied to the correct roaming folder...(as well as a whole bunch of other folders)..but no go
I am on windows 7 64 bit.
Regards
I have used this addon for years and was happy to discover there is an update for 2013. Although I cannot get it running. I have installed using the Installer and even tried manually to get to load, no joy. What I'm I missing?
Do you get any errors when you run the Install_64.bat file? If so what are they. Also it may be something to try and change the following line in the .BAT file:
C:\WINDOWS\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe /codebase SheetMetalExtents.dll
to this
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\RegAsm.exe /codebase SheetMetalExtents.dll
I have not tried this but have been told that it does work as well.
@Mike.Wohletz wrote:Do you get any errors when you run the Install_64.bat file? If so what are they. Also it may be something to try and change the following line in the .BAT file:
C:\WINDOWS\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe /codebase SheetMetalExtents.dllto this
I have made that same correction to the .bat file. After running the .bat at the Cmd Prompt I got the following:
RegAsm : warning RA0000 : Registering an unsigned assembly with /codebase can cause your assembly to interfere with other applications that may be installed on the same computer. The /codebase switch is intended to be used only with signed assemblies. Please give your assembly a strong name and re-register it. Types regisetered succesfully
It still doesn't work.
I really had to bring this up... but I am having trouble with this again. When I create a new part and flatten it, I get the SM extents in the parameters. Problems start when I make a change to the part. As soon as I exit the sketch, I get an error "Unexpected error while updating the property values with the sheet metal extents. The results should not be used.".
Of course, when I check the parameters, the value is not correct. I can do a Manage>Rebuild and that will update the parameter values. Then if I make another change to the sketch, I get the error again.
I am using the .dll that is in Mike's .zip file above on 5-1-2012.`
I am running SP1.1..... not sure if that is what broke this or not.
Anyone else seeing this?
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1
Vault 2013
I just installed SP1 today and will let you know if i notice anything. I use this addin daily so will let you know ASAP.
I will tell you that since running 2013 with this addin, I have noticed that message way more than in the past. I know some of the things that will cause that message every time like holes and cuts in the sheetmetal part or holes made by the bolted connection generator. I have definitely noticed that I need to perform rebuilds more often at the part level to ensure the addin is giving me the most up to date numbers.
Rob
I loved this dll add-on but gave up on it a few months ago because of this problem. What I ended up doing was using the same function from iPropWiz (http://www.ipropwiz.com/index.html) which I already had (and thoroughly recommend) and mapped the 2 custom properties I needed (SheetMetalLength and SheetMetalWidth) to the 2 iPropWiz properties (ipwFlatExtentsX and ipwFlatExtentsY).
Brendan,
There is a slight difference between the iLogic code and the mapping that you are doing with iPropsWiz. The iLogic code above actually writes the SheetMetalLength and SheetMetalWidth as user parameters in the part properties. The parameters are then used in the idw parts lists.
The way that I have our idws set-up (from way back), one column is the "Cutlength" and this is mapped to the sheetmetallength in the user parameters.
Not saying either way is right or wrong, its just a different way to skin the cat.
Kirk
Trying to correct this issue, I tried the three different methods that Brian talks about on his blog. I could not get any of them to work, but I was able to use the .dll from the Installer method.
I used the old "Install_64.bat" to get it installed, then overwrote the old dll with the one from the Installer method. It works now.
Sorry for the delay in responding. I have found a problem. Attached is a new installer. It will install the add-in along with a zip file that contains the source code. Let me know if there are any problems running it.
Thanks for the update, this corrected my install problem!
John
@ekinsb wrote:Sorry for the delay in responding. I have found a problem. Attached is a new installer. It will install the add-in along with a zip file that contains the source code. Let me know if there are any problems running it.
