Take a look in the API Help Files, there are the following properties:
FlatBendResult.kFactor Property
UnfoldMethod.kFactor Property
I hope it helps,
Philippe.
I have the same question I have created the ilogi lines shown below, but are unfinish any help?:
Sub oKFactor()
doc = ThisDoc.Document
Dim aOa As String
oSDef = doc.ComponentDefinition
For Each oEachMethod In oSDef.UnfoldMethods
If oEachMethod.UnfoldMethodType = UnfoldMethodTypeEnum.kLinearUnfoldMethod Then
Select Case iProperties.Value("Project", "Material")
Case "ALUMINIUM"
oEachMethod.kFactor = "0.50"
Case "MILD/ST"
oEachMethod.kFactor = "0.44"
Case "ST/ST (304L)"
oEachMethod.kFactor = "0.36"
Case Else
End Select
End If
Next
kFactor = SheetMetal.ActiveKFactor
MessageBox.Show(kFactor , "K Factor")
End Sub
The iLogic rule should work, I just tested it here if I set the document material to one of that in your Select Case, it does update the kFactor's value.
