Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Selecting (SelectSet) an Item from the Model Browser in a DrawingDocument
1 REPLY 1
977 Views, 1 Reply
Hello All,
I want to fetch either,
<> The name of the item selected OR
<> The componentOccurrence.Name of the referenced Assembly OR
<> (the best) The DrawingCurve(s) selected in the Window
Keep in mind that the idea is it to allow the user to make more than one selection (i.e. multiple components in browser window)
I have an alternative to make the user to manually select the drawingCurves in the Window, but that is not an elegnt solution to hat I am trying to achive.
If anyone can give me a heads up on what is the object type of the item I am selecting (I tried ComponentOccurrence but failed), even that would be very helpful.
Thanking you all,
Wajih
1 REPLY 1
adam.nagy
Hi Wajih,
If I understand you correctly then the following VBA code should be of help:
Function GetSelectedItems(nodes As BrowserNodesEnumerator) As String
    Dim node As BrowserNode
    For Each node In nodes
        If node.Selected Then
            GetSelectedItems = GetSelectedItems + vbCrLf + node.BrowserNodeDefinition.Label
        GetSelectedItems = GetSelectedItems + GetSelectedItems(node.BrowserNodes)
    Next
End Function
Sub GetSelectedItemsInBrowser()
    Dim bp As BrowserPane
    Set bp = ThisApplication.ActiveDocument.BrowserPanes("DlHierarchy")
    Dim items As String
    items = GetSelectedItems(bp.TopNode.BrowserNodes)
    MsgBox items
End Sub
Cheers,
Adam Nagy
Autodesk Platform Services
