style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<matt_jlt> wrote in messageI
href="news:6130229@discussion.autodesk.com">news:6130229@discussion.autodesk.com...
have a select set that contains only faces. What i can't work out is how to
access the properties all of the faces in the select set as i need to set the
render style of them all. Any on have any ideas? Thanks,
Matt
<matt_jlt> wrote in messageSorry
href="news:6131062@discussion.autodesk.com">news:6131062@discussion.autodesk.com...
mate i should have made it a bit clearer, What i am trying to do is to apply
the render style to all of the faces at once. The method you suggested is what
i currently use but it applies the render style to every face one at a time.
Because the files i am using have thousands of faces this takes up a lot of
time to do it this way. So if anyone has any ideas it is much appreciated as
ive hit a brick wall on this one. Cheers
