Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Saveas STP -save options
2 REPLIES 2
Ktelang
435 Views, 2 Replies
How can I access the save option while saving stp
Call oDoc.SaveAs("C:\temp\test.stp", True)
using this I get the default "include sketches" options
I want to exclude sketches using API
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
2 REPLIES 2
ekinsb
in reply to: Ktelang
When using the SaveAs method you get the default behavior and don't have control over the various translator settings.  In order to control the setting you need to drive the translator directly.  There are several samples in the API help that demonstrate this and there's on in particular that shows how to write out a STEP file.  The sample doesn't show all of the options that are available.  That's also listed in the API help but when I just looked for it now found it's not accessible through the index.  Instead you have to search for it.  We need to correct this.  In the meantime, I copied and pasted the material in a Word document, which I've attached.  You'll see the option for excluding sketches there.
Brian Ekins
Mod the Machine blog
Ktelang
in reply to: ekinsb
Thanks Brian,
oOptions.Value("IncludeSketches") = False
This did the trick
