Inventor Customization
Valued Contributor
Message 1 of 5 (1,230 Views)
Accepted Solution
SaveAs Stp
1230 Views, 4 Replies
09-30-2010 06:29 AM
I'm trying to start up Inventor, open an assembly and save it to stp using API (C#).
This works perfectly fine with parts, but not with assemblies.
doc.SaveAs("fil.stp", true); // doc is an iam-file (Inventor.Document)
...gives me error: "Invalid parameter... HRESULT: 0x80070057 (E_INVALIDARG))".
I start up Inventor visually so I know that the assembly opens up correctly with all parts and subassemblies.
If I do it manually it works fine with Export -> CAD Format -> STEP (stp).
Does anyone have any ideas why or what I'm doing wrong?
Thanks!
Board Manager
Message 2 of 5 (1,226 Views)
Re: SaveAs Stp
09-30-2010 11:57 AM in reply to: simonsson
Can you try providing that full path for the output file, rather than just "fil.stp"? I tried the following VBA macro on the active assembly document in Inventor 2011 and it works for me.
Sub SaveAsSTP()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    Call oDoc.SaveAs("C:\temp\test.stp", True)
End Sub
Valued Contributor
Message 3 of 5 (1,214 Views)
Re: SaveAs Stp
10-01-2010 02:46 AM in reply to: sanjay.ramaswamy
I found the problem. Inventor was not ready loading when I opened the assembly. Thanks!
New Member
Belero
Message 4 of 5 (919 Views)
Re: SavAs Step
03-28-2011 01:42 AM in reply to: simonsson
Would it be possible to add options for the step export within the code?
Specifically, does the export step have savecopyas options that can be set just like in the dxf/pdf translator addin?
Goal: I want to preset the export options for the step file.
options I would like to "grab" & "set":
- Application Protocol: 203 or 214, then 214 alone, 214 IS or 214 DIS.
- Include Sketches (True/False I guess)
regards
Valued Mentor
Ktelang
Message 5 of 5 (516 Views)
Re: SaveAs Stp
11-14-2012 07:46 AM in reply to: sanjay.ramaswamy
How can I access the saving options.
I want to exclude the sketches while saving as stp
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
