Sample for Ribbon and buttons
6 REPLIES 6
GeorgK
347 Views, 6 Replies
Hello together,
is there a sample for the different buttons (PopUp, ButtonPopUp, SplitButton, SplitButtonMRU, ComboBox, Quick Access Toolbar)?
Thank you very much
Georg
6 REPLIES 6
in reply to: GeorgK
Hi GeorgK
You can refer the following link.
Done by Autodesk experts,
http://adndevblog.typepad.com/manufacturing/2013/02/design-patterns-applied-to-the-inventor-api.html
GeorgK
Hello Sjoshi,
is there a sample without the Ribbon Builder?
Georg
in reply to: GeorgK
Hi Georg, A sample for adding new commands to the RMB action without picking existing commands from the Inventor Ribbon? Regards, Aditya
philippe.leefsma
Hi Georg,
The source code for the RibbonBuilder is provided in the link that was mentioned, so you can simply take a look at it.
Otherwise you can find some sample in the API Help Files or the Inventor training material (Module 9) but they are not exhaustive. It's pretty similar to create one or the other ribbon item types, so if you have a specific question let us know.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
GeorgK
in reply to: philippe.leefsma
Hello Philippe,
I took a look at the samples. But there is no sample for the PopUp, ButtonPopUp, SplitButton, SplitButtonMRU, ComboBox, DockableWindows with some buttons. Please could you help me with an example. The rest of the add-in works very well.
Thank you
Georg
philippe.leefsma
in reply to: GeorgK
Attached is a sample that contains some ribbon item examples, it's not 100% clean, but should help you to get started. There is no major technical difficulty in creating those ribbon controls.
The following blog post illustrates an example to create a Dockable Window. Basically it can contain any .Net UserControl, so designing such a window is the same than designing a .Net form:
http://adndevblog.typepad.com/manufacturing/2012/06/embedding-a-wpf-user-control-in-a-dockablewindow...
Philippe.
Philippe Leefsma
