Hello together,
I tried the code from the 2014 API Help. But it does not work. What's wrong with it?
Thank you Georg
' This sample demonstrates how to change colors using mini-toolbar Sub ChangeAppearanceMiniToolbarSample() Dim oDoc As PartDocument If Not (ThisApplication.ActiveDocument Is Nothing) Then If ThisApplication.ActiveDocument.DocumentType = kPartDocumentObject Then If (MsgBox("Would you like to create new appearance assets with active document?", vbYesNo, "Autodesk Inventor Prompt") = vbYes) Then Set oDoc = ThisApplication.ActiveDocument Else Set oDoc = ThisApplication.Documents.Add(kPartDocumentObject) ' Create a block Call CreateSolids(oDoc) End If End If Else Set oDoc = ThisApplication.Documents.Add(kPartDocumentObject) ' Create a block Call CreateSolids(oDoc) End If ' Create seven appearances for use Call CreateColors(oDoc) Dim oCamera As Camera Set oCamera = oDoc.Views(1).Camera oCamera.Fit oCamera.Apply Dim oMiniToolbarEvents As New clsColorChange ' <= here's the error userdefined type not declared Call oMiniToolbarEvents.Init(oDoc) End Sub Private Sub CreateSolids(oDoc As PartDocument) Dim oSk As PlanarSketch Set oSk = oDoc.ComponentDefinition.Sketches.Add(oDoc.ComponentDefinition.WorkPlanes(3)) Call oSk.SketchLines.AddAsTwoPointRectangle(ThisApplication.TransientGeometry.CreatePoint2d(-2, -2), ThisApplication.TransientGeometry.CreatePoint2d(2, 2)) Dim oProfile As Profile Set oProfile = oSk.Profiles.AddForSolid Dim oBlockDef As ExtrudeDefinition Set oBlockDef = oDoc.ComponentDefinition.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation) Call oBlockDef.SetDistanceExtent(4, kSymmetricExtentDirection) Dim oBlock As ExtrudeFeature Set oBlock = oDoc.ComponentDefinition.Features.ExtrudeFeatures.Add(oBlockDef) Set oSk = oDoc.ComponentDefinition.Sketches.Add(oBlock.EndFaces(1)) Call oSk.SketchCircles.AddByCenterRadius(ThisApplication.TransientGeometry.CreatePoint2d(12, 12), 2) Set oProfile = oSk.Profiles.AddForSolid Dim oCylinderDef As ExtrudeDefinition, oCylinder As ExtrudeFeature Set oCylinderDef = oDoc.ComponentDefinition.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kNewBodyOperation) Call oCylinderDef.SetDistanceExtent(4, kSymmetricExtentDirection) Set oCylinder = oDoc.ComponentDefinition.Features.ExtrudeFeatures.Add(oCylinderDef) End Sub Private Sub CreateColors(oDoc As PartDocument) Dim bCreateNewAppearance As Boolean: bCreateNewAppearance = False Dim oCreateColors As Transaction Set oCreateColors = ThisApplication.TransactionManager.StartTransaction(oDoc, "Create custom colors") On Error Resume Next Dim oAsset As Asset, oColor As Color Set oAsset = oDoc.Assets.Item("Red") If Err Then Set oAsset = oDoc.Assets.Add(kAssetTypeAppearance, "Generic", "Red", "Red") ' Add Red Set oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0) oAsset.Item("generic_diffuse").Value = oColor bCreateNewAppearance = True Err.Clear End If Set oAsset = oDoc.Assets.Item("Orange") If Err Then Set oAsset = oDoc.Assets.Add(kAssetTypeAppearance, "Generic", "Orange", "Orange") ' Add Orange Set oColor = ThisApplication.TransientObjects.CreateColor(255, 165, 0) oAsset.Item("generic_diffuse").Value = oColor bCreateNewAppearance = True Err.Clear End If Set oAsset = oDoc.Assets.Item("Yellow") If Err Then Set oAsset = oDoc.Assets.Add(kAssetTypeAppearance, "Generic", "Yellow", "Yellow") ' Add Yellow Set oColor = ThisApplication.TransientObjects.CreateColor(255, 255, 0) oAsset.Item("generic_diffuse").Value = oColor bCreateNewAppearance = True Err.Clear End If Set oAsset = oDoc.Assets.Item("Green") If Err Then Set oAsset = oDoc.Assets.Add(kAssetTypeAppearance, "Generic", "Green", "Green") ' Add Green Set oColor = ThisApplication.TransientObjects.CreateColor(0, 255, 0) oAsset.Item("generic_diffuse").Value = oColor bCreateNewAppearance = True Err.Clear End If Set oAsset = oDoc.Assets.Item("Blue") If Err Then Set oAsset = oDoc.Assets.Add(kAssetTypeAppearance, "Generic", "Blue", "Blue") ' Add Blue Set oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 255) oAsset.Item("generic_diffuse").Value = oColor bCreateNewAppearance = True Err.Clear End If Set oAsset = oDoc.Assets.Item("Indigo") If Err Then Set oAsset = oDoc.Assets.Add(kAssetTypeAppearance, "Generic", "Indigo", "Indigo") ' Add Indigo Set oColor = ThisApplication.TransientObjects.CreateColor(75, 0, 130) oAsset.Item("generic_diffuse").Value = oColor bCreateNewAppearance = True Err.Clear End If Set oAsset = oDoc.Assets.Item("Purple") If Err Then Set oAsset = oDoc.Assets.Add(kAssetTypeAppearance, "Generic", "Purple", "Purple") ' Add Purple Set oColor = ThisApplication.TransientObjects.CreateColor(160, 32, 240) oAsset.Item("generic_diffuse").Value = oColor bCreateNewAppearance = True Err.Clear End If If bCreateNewAppearance Then oCreateColors.End Else oCreateColors.Abort End If End Sub '************************************************************* ' The declarations and functions below need to be copied into ' a class module whose name is "clsColorChange". The name ' can be changed but you'll need to change the declaration in ' the calling function "ChangeAppearanceMiniToolbarSample" to use the new name. Private WithEvents m_MiniToolbar As MiniToolbar Private WithEvents m_Colors As MiniToolbarComboBox Private WithEvents m_Filter As MiniToolbarDropdown Private WithEvents m_Preview As MiniToolbarCheckBox Private m_PreviewColor As MiniToolbarCheckBox Private WithEvents oInteractionEvents As InteractionEvents Private WithEvents m_SelectEvents As SelectEvents Private m_ChangeColorTransaction As Transaction Private m_Doc As PartDocument Private m_DefaultColor As Asset Private bIsinteractionStarted As Boolean Private bNeedTransaction As Boolean Private bStop As Boolean Public Sub Init(oDoc As PartDocument) Set m_Doc = oDoc Set m_DefaultColor = m_Doc.ActiveAppearance ' Create interaction events Set oInteractionEvents = ThisApplication.CommandManager.CreateInteractionEvents 'oInteractionEvents.InteractionDisabled = False Set m_SelectEvents = oInteractionEvents.SelectEvents 'm_SelectEvents.ClearSelectionFilter 'm_SelectEvents.SingleSelectEnabled = False 'm_SelectEvents.Enabled = True ' Create mini-tool bar for changing appearance Set m_MiniToolbar = oInteractionEvents.CreateMiniToolbar Call InitiateMiniToolbar bStop = False Set m_ChangeColorTransaction = ThisApplication.TransactionManager.StartTransaction(m_Doc, "Change Appearance") Do ThisApplication.UserInterfaceManager.DoEvents Loop Until bStop End Sub Private Sub InitiateMiniToolbar() m_MiniToolbar.ShowOK = True m_MiniToolbar.ShowApply = True m_MiniToolbar.ShowCancel = True Dim oControls As MiniToolbarControls Set oControls = m_MiniToolbar.Controls oControls.Item("MTB_Options").Visible = False Set m_Filter = m_MiniToolbar.Controls.AddDropdown("Filter", False, True, True, False) Call m_Filter.AddItem("Part", "Part", "Filter_Part", False, False) Call m_Filter.AddItem("Feature", "Feature", "Filter_Feature", False, False) Call m_Filter.AddItem("Face", "Face", "Filter_Face", False, False) Set m_Colors = oControls.AddComboBox("Colors", True, True, 50) Call m_Colors.AddItem("Default", "Use default color", "Default", False) Call m_Colors.AddItem("Red", "Red", "Red", False) Call m_Colors.AddItem("Orange", "Orange", "Orange", False) Call m_Colors.AddItem("Yellow", "Yellow", "Yellow", False) Call m_Colors.AddItem("Green", "Green", "Green", False) Call m_Colors.AddItem("Blue", "Blue", "Blue", False) Call m_Colors.AddItem("Indigo", "Indigo", "Indigo", False) Call m_Colors.AddItem("Purple", "Purple", "Purple", False) oControls.AddNewLine ' Specify if preview the color when hover a color item Set m_PreviewColor = m_MiniToolbar.Controls.AddCheckBox("PreviewColor", "Hover color preview", "Whether preview color when hover on it", True) ' Position the mini-tool bar to the top-left. Dim oPosition As Point2d Set oPosition = ThisApplication.TransientGeometry.CreatePoint2d(0, 0) m_MiniToolbar.Visible = True m_MiniToolbar.Position = oPosition End Sub Private Sub m_Colors_OnItemHoverStart(ByVal ListItem As MiniToolbarListItem) ' Preview the color when hover on it. If m_PreviewColor.Checked Then Call ChangeColor(ListItem.Text) End If End Sub Private Sub m_Colors_OnSelect(ByVal ListItem As MiniToolbarListItem) ' Check if the selected color is already used for the part/objects If m_Filter.SelectedItem.Text = "Part" Then If m_Doc.ActiveAppearance.Name = ListItem.Text Then bNeedTransaction = False Else bNeedTransaction = True End If Else bNeedTransaction = True End If Call ChangeColor(ListItem.Text) End Sub ' Change filter for assigning color Private Sub m_Filter_OnSelect(ByVal ListItem As MiniToolbarListItem) If ThisApplication.TransactionManager.CurrentTransaction.DisplayName = "Change Appearance" Then ThisApplication.TransactionManager.CurrentTransaction.Abort End If Set m_ChangeColorTransaction = ThisApplication.TransactionManager.StartTransaction(m_Doc, "Change Appearance") Select Case ListItem.Text Case "Part" m_Doc.SelectSet.Clear m_SelectEvents.ResetSelections m_SelectEvents.ClearSelectionFilter m_SelectEvents.AddSelectionFilter kPartDefaultFilter oInteractionEvents.SetCursor kCursorTypeDefault Case "Feature" m_Doc.SelectSet.Clear m_SelectEvents.ResetSelections m_SelectEvents.ClearSelectionFilter m_SelectEvents.AddSelectionFilter kPartFeatureFilter If Not bIsinteractionStarted Then oInteractionEvents.Start bIsinteractionStarted = True End If Case "Face" m_Doc.SelectSet.Clear m_SelectEvents.ResetSelections m_SelectEvents.ClearSelectionFilter m_SelectEvents.AddSelectionFilter kPartFaceFilter If Not bIsinteractionStarted Then oInteractionEvents.Start bIsinteractionStarted = True End If End Select m_Doc.Views(1).Update Call ChangeColor(ListItem.Text) End Sub Private Sub m_MiniToolbar_OnApply() If (m_Filter.SelectedItem.Text = "Feature" Or m_Filter.SelectedItem.Text = "Face") And (m_SelectEvents.SelectedEntities.Count = 0) Then m_ChangeColorTransaction.Abort m_Doc.Views(1).Update Set m_ChangeColorTransaction = ThisApplication.TransactionManager.StartTransaction(m_Doc, "Change Appearance") Exit Sub Else If bNeedTransaction Then ' Change color style Call ChangeColor(m_Colors.SelectedItem.Text) m_ChangeColorTransaction.End Else ' If no change to the color style m_ChangeColorTransaction.Abort End If ' Clear current selection for Feature and Face filter. If (m_Filter.SelectedItem.Text = "Feature" Or m_Filter.SelectedItem.Text = "Face") Then m_Doc.SelectSet.Clear m_SelectEvents.ResetSelections End If End If Set m_ChangeColorTransaction = ThisApplication.TransactionManager.StartTransaction(m_Doc, "Change Appearance") End Sub Private Sub m_MiniToolbar_OnCancel() bStop = True If ThisApplication.TransactionManager.CurrentTransaction Is m_ChangeColorTransaction Then m_ChangeColorTransaction.Abort End If m_SelectEvents.AddSelectionFilter kPartDefaultFilter If bIsinteractionStarted Then oInteractionEvents.Stop m_Doc.Views(1).Update End Sub Private Sub m_MiniToolbar_OnOK() bStop = True If bNeedTransaction Then ' Change color Call ChangeColor(m_Colors.SelectedItem.Text) m_ChangeColorTransaction.End Else ' If no change to the color style m_ChangeColorTransaction.Abort End If End Sub Private Sub oInteractionEvents_OnTerminate() If ThisApplication.TransactionManager.CurrentTransaction Is m_ChangeColorTransaction Then m_ChangeColorTransaction.Abort End If If bIsinteractionStarted Then oInteractionEvents.Stop End If m_Doc.Views(1).Update End Sub Private Sub ChangeColor(sColor As String) Debug.Print "Passed in:" & sColor If m_Filter.SelectedItem.Text = "Part" Then Select Case sColor Case "Default" m_Doc.ActiveAppearance = m_DefaultColor Case "Red", "Orange", "Yellow", "Green", "Blue", "Indigo", "Purple" m_Doc.ActiveAppearance = m_Doc.AppearanceAssets.Item(sColor) End Select ElseIf m_Filter.SelectedItem.Text = "Feature" Then If m_SelectEvents.SelectedEntities.Count Then Dim oFeature As PartFeature, oSelectedObj As Object For Each oSelectedObj In m_SelectEvents.SelectedEntities If InStr(1, TypeName(oSelectedObj), "Feature") Then Set oFeature = oSelectedObj Select Case sColor 'm_Colors.SelectedItem.Text Case "Default" oFeature.Appearance = m_DefaultColor Case "Red", "Orange", "Yellow", "Green", "Blue", "Indigo", "Purple" oFeature.Appearance = m_Doc.AppearanceAssets.Item(sColor) End Select End If Next End If ElseIf m_Filter.SelectedItem.Text = "Face" Then If m_SelectEvents.SelectedEntities.Count Then Dim oFace As Face For Each oSelectedObj In m_SelectEvents.SelectedEntities If InStr(1, TypeName(oSelectedObj), "Face") Then Set oFace = oSelectedObj Select Case sColor Case "Default" oFace.Appearance = m_DefaultColor Case "Red", "Orange", "Yellow", "Green", "Blue", "Indigo", "Purple" oFace.Appearance = m_Doc.AppearanceAssets.Item(sColor) End Select End If Next End If End If End Sub
Solved by ekinsb. Go to Solution.
The short description at the top of the sample could definitely be better, but notice a several line comment about 1/3 of the way down in the code. All of the code past that point needs to be copied into a class module named "clsColorChange". That should be the only issue because I just tested it and it ran fine once I did that. The other thing that's not obvious is that you execute the sample by running the sub "ChangeAppearanceMiniToolbarSample".
