Run ilogic rule in each part from the assembly via external rule?
20 REPLIES 20
Message 1 of 21
guyh
7329 Views, 20 Replies
I want to simply set a custom iproperty as the Description in each part file within my assembly.  I can do this easily at part level with ilogic but I want to be able to run the rule from the assembly level and all the parts run the rule.  I am struggling to find a way to do this.
I think this may be the best method I have found but I think it must be far easier?
http://inventortrenches.blogspot.com/search/label/Autodesk%20Inventor%20iLogic
Guy
AutoCADM 2011 SP2
Inventor Pro 2011 SP2
20 REPLIES 20
Message 2 of 21
MegaJerk
in reply to: guyh
Will the description be something that is derived from a parameter within each part, a manual entry, or perhaps a parameter in the assembly, OR something just hardcoded?
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Message 3 of 21
guyh
in reply to: MegaJerk
We have a PLM system which populates a custom iproperty with the description entered in the PLM.  We also have some old parts which have the description in the Description field but not the custom iproperty.  I want to write a rule which will ensure I can call the Description field in a parts list.  If I do this currently some descriptions are blank.
Can you help?
Guy
AutoCADM 2011 SP2
Message 4 of 21
MegaJerk
in reply to: guyh
So your PLM system does a lot of the grunt work of populating the custom iprop. You just want to make sure that the custom iprop exists, correct?
GitHub
Message 5 of 21
guyh
I want to make sure that if the custom iprop exists it is copied to the Description field under the project tab.  I think it's dangerous to copy the other way as this is data placed in the part from the PLM system.   That way I can run the rule in the assembly and ensure I have the description for each part in my Parts List.  Some of the legacy parts in the PLM had the description stored in the Description field.
I do not know why it was changed......
cheers,
Guy
AutoCADM 2011 SP2
Message 6 of 21
MegaJerk
in reply to: guyh
Alright. I made this during lunch just now, and have not tested it, but you should be able to throw this into a rule in the main assembly file and let it do its thing.
Basically it just goes through all of the parts in the assembly, and will set the Project's - Description iproperty, to match a custom iproperty of your desire. Just be sure to replace the custom iproperty name in the code with the one you'll be using.
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim docFile As Document
If openDoc.DocumentType = 12291 Then
	For Each docFile In openDoc.AllReferencedDocuments
		If docFile.DocumentType = 12290 Then
			iProperties.Value(docFile.DisplayName, "Project", "Description") = iProperties.Value(docFile.DisplayName, "Custom", "YOURiPropNAMEHERE")
		End If
	Next
End If
GitHub
Message 7 of 21
guyh
Hi Sorry for the delay replying.  Start of the day in the UK now.
Thanks a lot for the help and the rule.  I tried it and receive an error when it's run.
I've used a test assembly.  Here is the detail of the message
Cheers,
Guy
AutoCADM 2011 SP2
Message 8 of 21
MegaJerk
in reply to: guyh
I just tested this. It should work, but it assumes that you have your occurrence names set to the filename, and that there is always one of them named with the suffix of “:1” (So if you have a filename called FrankyLovesCake.ipt it assumes the Occurrence name is FrankyLovesCake:1).
Later on, I’ll try to make this more solid and less awful.
New Code :
Dim OccName As String
OccName = Left(docFile.DisplayName, Len(docFile.DisplayName) - 4) & ":1"
iProperties.Value(OccName, "Project", "Description") = iProperties.Value(OccName, "Custom", "CUSTOM_NAME_HERE")
End If
Next
End If
GitHub
Message 9 of 21
guyh
Thanks I really appreciate the help.  The file name and occurrence names differ unfortunately.  As an example.  The file name = doc-0000837756_0.ipt yet the occurrence name = DOC-0000837756-PART_GLFT_0003-PART-ID-2301831:1
This is generated by the software we have which links to the PLM.
Cheers,
Guy
AutoCADM 2011 SP2
Message 10 of 21
MegaJerk
in reply to: guyh
Yeah. I figured that might be the case. Once I get some time, I'll change how it goes about messing with things, and maybe all will be well in the end!.
GitHub
Message 11 of 21
MegaJerk
in reply to: guyh
Alright. This will go through every part and change the Description to the Custom Iprop without all the nasty errors or messes.
Just make a new rule in your assembly and give it a go.
			Dim assemblyDoc As AssemblyDocument
			assemblyDoc = openDoc
			Dim assemblyDef As AssemblyComponentDefinition
			assemblyDef = assemblyDoc.ComponentDefinition
			Dim partDoc As PartDocument
			partDoc = ThisApplication.Documents.Open(docFile.FullFileName, False)
			iProperties.Value(docFile.DisplayName, "Project", "Description") = iProperties.Value(docFile.DisplayName, "Custom", "CUSTOM_NAME_HERE")
			Else
			'''iProperties.Value(docFile.DisplayName, "Project", "Description") = "Assembly"
			'''Don't really know if you want anything to happen if there is a Sub Assembly that this code comes across.
			'''If not, you could just take this entire else portion out.
		End If
	Next
	Else
	MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
End If
GitHub
Message 12 of 21
guyh
Thanks again.  I tried this on the same assembly and it failed.  I made a new assembly and this also failed.  It failed on the same issue as before.  I have attached the new simple 2 part assembly.  These parts have the description in the custom property so the rule should copy this to the project description.
Maybe you can see some issue with these files?
cheers,
Guy
AutoCADM 2011 SP2
Message 13 of 21
MegaJerk
in reply to: guyh
I found the problem. The line that used to read:
iProperties.Value(docFile.DisplayName, "Project", "Description") = iProperties.Value(docFile.DisplayName, "Custom", "DISPLAY_NAME")
Now reads:
iProperties.Value(docFName, "Project", "Description") = iProperties.Value(docFName, "Custom", "DISPLAY_NAME")
Because I did not take into consideration that your part names might be balanced, it was attempting to locate the iproperties of an instance it didn’t recognize.
If you right click and open your part (from the assembly), you’ll see that the root name is without any file extension. It would call on that DisplayName, but because it is neither a file (as it has no extension), nor is it an instance (because it would need a “:#” behind it to indicate the occurrence), it just freaks out.
Needless to say, the code above fixes this by looking at the actual file path of the document and shortening it down to just the file name of the part. That way it should always pull correctly… I hope.
This was actually a lesson for me! Pull from the darn part file name forever!
New iLogic Rule is below.
			Dim FNamePos As Long
            FNamePos = InStrRev(docFile.FullFileName, "\", -1)
            Dim docFName As String
            docFName = Mid(docFile.FullFileName, FNamePos + 1, Len(docFile.FullFileName) - FNamePos)
			Else
		End If
	Next
	Else
End If
GitHub
Message 14 of 21
guyh
Great, thanks!  works a treat.  Glad you were able to learn something as well Smiley Wink  (Joke)
Really appreciate the help.  I am going to study the rule a bit and improve my knowledge.
Cheers,
Guy
AutoCADM 2011 SP2
Message 15 of 21
MegaJerk
in reply to: guyh
Improved less awful code :
            docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
		End If
	Next
	Else
End If
GitHub
Message 16 of 21
guyh
Thanks, I'll give it a try.  I want to try and adapt it a bit to skip parts where the custom property is blank (the old files already have the correct description in the description field.)
Cheers,
Guy
AutoCADM 2011 SP2
Message 17 of 21
guyh
in reply to: guyh
Ok so I added a little bit of code.  It seems to work.
			If iProperties.Value(docFName, "Project", "Description")="" Then
			End If
		End If
	Next
	Else
End If
AutoCADM 2011 SP2
Message 18 of 21
MegaJerk
in reply to: guyh
Looks like it's all sorted out then!
GitHub
Message 19 of 21
DeerSpotter
in reply to: guyh
Here is a better Method to those in the Future
iLogicVb.RunRule("component name", "ilogic rule")
ThisDoc.Document.Rebuild()
Image and video hosting by TinyPic
See My LinkedIn Profile
Message 20 of 21
kevinDMTWZ
Hi, just seen one of your posts about running an ilogic rule from assembly level in each part. I'm trying to do something similar but with external rules. Basically I've started with your code for opening each part in the assembly but I can't then get to the next step.
What I want to do is have every part open (in the background) and then trigger another external rule to run in each part. I can see in the ilogic window that there is a "RunRule in component" option but I don't know how to get that to trigger an external rule - if that is even possible.
Any input would be greatly appreciated!!
Cheers,
Kevin
