This run-time error 91 doesn't make sense to me. Generally the issue is I didn't define something, but I've noted everything this time.
The error is on this line:
Set f = ThisApplication.ActiveDocument.File
ThisApplication is defined towards the beginning. File is defined right before that line.
Here is my code:
Option Explicit Public Sub ReplaceReference() Dim invApp As Inventor.Application Set invApp = ThisApplication Dim NameStr As String Dim NewNamePath As String Dim NameStr2 As String Dim OldNamePath As String NameStr = Renamer.New_Name.Text 'Concatenates the full new file path NewNamePath = Renamer.Path_Text.Text & "\" + NameStr & "-" & Right("00" & i, 3) & ".ipt" If Err.Number <> 0 Then MsgBox "Error Found After NewNamePath:" & Err.Description Err.Clear NameStr2 = Renamer.Old_Name_Display.Text 'Concatenates the old file NAME OldNamePath = NameStr2 & "-" & Right("00" & i, 3) & ".ipt" If Err.Number <> 0 Then MsgBox "Error Found After OldNamePath:" & Err.Description Err.Clear Do While i < 99 Dim f As File Set f = ThisApplication.ActiveDocument.File Dim fd As FileDescriptor For Each fd In f.ReferencedFileDescriptors If fd.FullFileName = OldNamePath Then fd.ReplaceReference (NewNamePath) End If Next Loop End Sub
I know run-time error 91 is common and seems silly, but I just don't know what is wrong with it.
Solved by rjay75. Go to Solution.
Looks like the Do/While is out of sequence. Your current code looks like it's looking for files that match an old file name and switchs the reference to the new file name.
One issue is Your Do While i < 99 is in the wrong spot. You set the name up top but begin looping after ward. i never changes. So it could be a memory error as you are running in an inifinite loop.
In your current code The Do While i < 99 should be like this.
Option Explicit Public Sub ReplaceReference() Dim invApp As Inventor.Application Set invApp = ThisApplication Dim NameStr As String Dim NewNamePath As String Dim NameStr2 As String Dim OldNamePath As String Do While i < 99 'Concatenates the full new file path NameStr = Renamer.New_Name.Text NewNamePath = Renamer.Path_Text.Text & "\" + NameStr & "-" & Right("00" & i, 3) & ".ipt" If Err.Number <> 0 Then MsgBox "Error Found After NewNamePath:" & Err.Description Err.Clear 'Concatenates the old file NAME NameStr2 = Renamer.Old_Name_Display.Text OldNamePath = NameStr2 & "-" & Right("00" & i, 3) & ".ipt" If Err.Number <> 0 Then MsgBox "Error Found After OldNamePath:" & Err.Description Err.Clear Dim f As File Set f = ThisApplication.ActiveDocument.File Dim fd As FileDescriptor For Each fd In f.ReferencedFileDescriptors If fd.FullFileName = OldNamePath Then fd.ReplaceReference (NewNamePath) End If Next Loop End Sub
While this may work there is some redunancies as well. Everytime it's going throught the For Each loop its looping through ever referenced file. In this case you're looping throug 99 times.
Here's an alternate version that loops through once working for any number of files.
Option Explicit Public Sub ReplaceReference() Dim invApp As Inventor.Application Set invApp = ThisApplication Dim NameStr As String Dim NewNamePath As String Dim NameStr2 As String Dim OldNamePath As String 'Concatenates the full new file path NameStr = Renamer.New_Name.Text NewNamePath = Renamer.Path_Text.Text & "\" If Err.Number <> 0 Then MsgBox "Error Found After NewNamePath:" & Err.Description Err.Clear 'Concatenates the old file NAME OldNamePath = Renamer.Old_Name_Display.Text If Err.Number <> 0 Then MsgBox "Error Found After OldNamePath:" & Err.Description Err.Clear Dim sLen As Long Dim sep As Long Dim fileName as String Dim f As File Dim fd As FileDescriptor Set f = ThisApplication.ActiveDocument.File For Each fd In f.ReferencedFileDescriptors sLen = Len(fd.FullFileName) sep = InStrRev(fd.FullFileName, "\") fileName = Right(fd.FullFileName, sLen - sep) If InStr(fileName, OldNamePath) = 1 Then fd.ReplaceReference (NewNamePath & Replace(fileName, OldNamePath, NameStr)) End If Next End Sub
This will get the new target directory and new prefix. Then it loops through the referenced files. If any file has a name beginning with the oldname it renames it replaces it with the new one.
Calling Replace("abcde-001.ipt", "abcde", "xyz") returns "xyz-001.ipt".
Ah, perfect. Something seemed off about where it was placed but I couldn't figure it out. Going off of your second solution (thanks for that, by the way), I do still get the same error, but this will be great once this error is fixed!!! Thanks, Rodney!
Aha, that moved on to a new error! Yippee! 😄 I opened an assembly when I did it. This creates a problem though. I need it to run without the assembly document being open when the program is first initialized. The user is supposed to select and open the assembly in part 3 of the program... Hmmm..
And I'm running 2011 here.
Now I get on run-time error 5 on this:
Baby steps, right? Haha
I added an "On Error Resume Next" to forego that problem (it seems to have worked....I think) but still having that new run-time 5 error now
Try this to see what is giving the error message
Change this line:
to
Dim newFileName As String = NewNamePath & Replace(fileName, OldNamePath, NameStr)
fd.ReplaceReference (newFileName)
This will to see which is failing. The string replace function or the ReplaceReference function. It may also fail if newFileName is not a valid file.
Got it to mock run through your code. And it worked ok with the final section looking like this.
Dim sLen As Long Dim sep As Long Dim FileName As String Dim f As File Dim fd As FileDescriptor Dim Names As String 'On Error Resume Next Set f = ThisApplication.ActiveDocument.File For Each fd In f.ReferencedFileDescriptors sLen = Len(fd.FullFileName) sep = InStrRev(fd.FullFileName, "\") FileName = Right(fd.FullFileName, sLen - sep) If InStr(FileName, OldNamePath) = 1 Then Dim NewFileName As String NewFileName = NewNamePath & Replace(FileName, OldNamePath, NameStr) fd.ReplaceReference (NewFileName) Names = Names & vbCrLf & NewFileName End If Next MsgBox Names
I commented out the Error trapping because we want to know if there's an error here. I added a Names variable so I can get a list of names and display at the end. When run it will show a dialog of all the replaced names. You can temporarily leave the error trap turned on so you can see the list of names to verify them so it doesn't stop on every error.
The error 5 is on the ReplaceReference call. There 2 reasons why this call is failing.
1. The file name you are trying to replace the reference on does not exist. (The path could be incorrect. Or the name itself could be incorrect.)
2. The file reference you are replacing is not the same as the one being replaced.
Try running it in an assembly that needs the references replaced with the new files existing already.
Do the replacement files exist at this point? If so were they created by just copying the originals?
Yes. Here is how the program works:
1. User runs program
2. The user clicks browse, which opens a folder dialog
3. In the background, a temporary folder called "Inventor Temp Folder" is created in the C: drive.
4. The contents of the user-selected folder are copied in to this temp folder
5. The user selects okay.
6. The user enters the old prefix of the files and the new one they want
7. The user selects okay
8. The user clicks "Browse for Assemblies", opening a file dialog limited to assembly searches
9. The user selects "Open" and the assembly opens
10. Files are replaced in the assembly with the new corresponding folders (tentative)
11. The temporary folder is deleted (tentative)
12. The assembly is saved and closed (tentative)
Would it be better if I made this a whole separate program? So, when the assembly is opened, it can set it to launch that program? Not sure how to do that, but could that fix these problems?
You're doing a manual copy design. A few notes and questions that I used to walk through the workflow.
c:\Project1
c:\Inventor Temp Folder
c:\Project1 -> c:\Inventor Temp Folder (The files should be renamed at this point)
Prj1 , Prj2
Prj1.asm or Prj2.asm (Should be Prj2.asm)
ReplaceReferences should run at this time point files to new location of c:\Inventor Temp Files\Prj2.....
The temporary folder holds the renamed files. They can't be deleted or moved at this point.
The assembly is closed and moved.
Since you don't have access to vault and would like to do this from Inventor here's an alternate workflow.
1. User opens assembly they wish to copy.
2. User does a SaveAs saving the assembly file to a new folder location.
3. Enters in Prefixes for the old and new files.
4. Programmatically open each referenced file and saveas the file to the new location and name. Close the referenced file. Replace the reference to the newly saved file name.
When I get a moment I can mock up what the saving/replace procedure looks like.
