Inventor Customization
Valued Contributor
Message 1 of 18 (846 Views)
Accepted Solution
Retrieve dimensions
846 Views, 17 Replies
10-08-2012 06:45 AM
I want to retrieve dimensions in a drawing with ilogic. I found some code in de api help, but i can't figure out how to translate it into a ilogic code.
I always use assembly models in these drawing and all the parameters have unique names. So in my drawing i want to retrieve some specific dimensions in a view.
Can anyone point me in the right direction? maybe a small sample?
kind regards,
theo
Message 2 of 18 (823 Views)
Re: Retrieve dimensions
10-09-2012 11:54 PM in reply to: theo.bot
Hello Theo,
Here you have a little example how-to retrieve dimensions with a special parameter name in iLogic.
The workflow I use is:
1. Retrieve all dimensions.
2. Iterate through the dimensions.
3. Delete dimensions if not a special parameter.
The special parameter name has a prefix “RetD_” as model / userparameter.
Start code”
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
Dim oDrawView As DrawingView = oSheet.DrawingViews(1)
Dim oGeneralDimensionsEnum As GeneralDimensionsEnumerator
oGeneralDimensionsEnum = oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oDrawView)
Dim PrefixStr As String = "RetD_"
Dim oGeneralDimension As GeneralDimension
For Each oGeneralDimension In oGeneralDimensionsEnum
    Dim oParameter As Parameter
    oParameter = oGeneralDimension.RetrievedFrom.Parameter
    If oParameter.DrivenBy.count <> 0 Then
        Dim oDrivenByParameter As Parameter
        For Each oDrivenByParameter In oParameter.DrivenBy
            If InStr(oDrivenByParameter.Name, PrefixStr) = 0 Then
                oGeneralDimension.Delete
        Next
                Else
        If InStr(oParameter.Name, PrefixStr) = 0 Then
Next
“End Code
I hoop it was use full.
Best regards,
Marco Suurlant
Programmer Engineering
inventor professional 2011 / 2012 / 2013
Distinguished Contributor
achmidt
Message 3 of 18 (809 Views)
10-10-2012 01:18 PM in reply to: marco.suurlant
Wow!!! That is the great code!!!!
Thank you so much!!!
Valued Contributor
Message 4 of 18 (798 Views)
10-11-2012 01:39 AM in reply to: theo.bot
:smileyvery-happy:
Marco,
Thanks, it works great!!
Houdoe,:smileywink:
gr Theo
Valued Mentor
jcneal
Message 5 of 18 (789 Views)
10-11-2012 05:17 AM in reply to: marco.suurlant
hi
will this rule delete dimensions by hole features?
it seems not going to work at that way.
thanks.
Autodesk Inventor Professional 2014
Autodesk Product Design Suite Standard 2013
Microsoft Office 2007 & 2013
Windows 7 64bit
Synergis Adept 2013
Visual Studio Express 2010
ADN Support Specialist
xiaodong.liang
Message 6 of 18 (749 Views)
10-16-2012 03:11 AM in reply to: jcneal
I'd suggest you provide a dataset to recreate the problem you met with. This will help the peers here to diagnose.
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Valued Mentor
jcneal
Message 7 of 18 (740 Views)
10-16-2012 05:06 AM in reply to: xiaodong.liang
HI,
please check attachment. there will be an error when run ilogic rule.
the dimension by hole feature is not going to work.
it is 1/4--20 hole. the diameter of tap drill hole casues the error.
thanks a lot.
Windows 7 64bit
Synergis Adept 2013
Message 8 of 18 (729 Views)
10-16-2012 07:17 AM in reply to: jcneal
You were right the code stopped working because the Tapped Hole has no RetrievedFrom.Parameter.
Here you have the modified code.
Start code”
	Try
	Catch
		' Error to set oParameter.
		' Go further to delete the dimension.
	End Try
            If InStr(oDrivenByParameter.Name, "RetD_") = 0 Then
        Next
    Else
Next
“End Code
I didn’t test it with your Part because I have now only version 2011.
Best regards,
Marco Suurlant
Valued Mentor
jcneal
Message 9 of 18 (725 Views)
10-16-2012 10:18 AM in reply to: marco.suurlant
hi,
at the near end of your code, you miss some parts. it should be like this,
If InStr(oParameter.Name, "test_") = 0 Then
otherwise, the code will delete all dimensions.
thanks for your information.
Windows 7 64bit
Synergis Adept 2013
Message 10 of 18 (717 Views)
10-16-2012 10:46 AM in reply to: jcneal
Something like this:
	Try
	Catch
	End Try
        Next
	Else
Next
Marco Suurlant
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
