Retrieve dimensions
21 REPLIES 21
Message 1 of 22
theo.bot
4671 Views, 21 Replies
Retrieve dimensions
I want to retrieve dimensions in a drawing with ilogic. I found some code in de api help, but i can't figure out how to translate it into a ilogic code.
I always use assembly models in these drawing and all the parameters have unique names. So in my drawing i want to retrieve some specific dimensions in a view.
Can anyone point me in the right direction? maybe a small sample?
kind regards,
theo
Tags (3)
21 REPLIES 21
Message 2 of 22
marco_suurlant
in reply to: theo.bot
Hello Theo,
Here you have a little example how-to retrieve dimensions with a special parameter name in iLogic.
The workflow I use is:
1. Retrieve all dimensions.
2. Iterate through the dimensions.
3. Delete dimensions if not a special parameter.
The special parameter name has a prefix “RetD_” as model / userparameter.
Start code”
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
Dim oDrawView As DrawingView = oSheet.DrawingViews(1)
Dim oGeneralDimensionsEnum As GeneralDimensionsEnumerator
oGeneralDimensionsEnum = oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oDrawView)
Dim PrefixStr As String = "RetD_"
Dim oGeneralDimension As GeneralDimension
For Each oGeneralDimension In oGeneralDimensionsEnum
    Dim oParameter As Parameter
    oParameter = oGeneralDimension.RetrievedFrom.Parameter
    If oParameter.DrivenBy.count <> 0 Then
        Dim oDrivenByParameter As Parameter
        For Each oDrivenByParameter In oParameter.DrivenBy
            If InStr(oDrivenByParameter.Name, PrefixStr) = 0 Then
                oGeneralDimension.Delete
            End If
        Next
                Else
        If InStr(oParameter.Name, PrefixStr) = 0 Then
        End If
    End If
Next
“End Code
I hoop it was use full.
Best regards,
Marco Suurlant
Programmer Engineering
inventor professional 2015
Message 3 of 22
achmidt
in reply to: marco_suurlant
Wow!!! That is the great code!!!!
Thank you so much!!!
Inventor Virtual Parts Addin
http://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3Avirtualpartsadd-in_windows32and64%3Aen
Message 4 of 22
theo.bot
Smiley Very Happy
Marco,
Thanks, it works great!!
Houdoe,Smiley Wink
gr Theo
Message 5 of 22
skyngu
hi
will this rule delete dimensions by hole features?
it seems not going to work at that way.
thanks.
Autodesk Inventor Professional 2019
Message 6 of 22
xiaodong_liang
in reply to: skyngu
I'd suggest you provide a dataset to recreate the problem you met with. This will help the peers here to diagnose.
Message 7 of 22
skyngu
in reply to: xiaodong_liang
HI,
please check attachment. there will be an error when run ilogic rule.
the dimension by hole feature is not going to work.
it is 1/4--20 hole. the diameter of tap drill hole casues the error.
thanks a lot.
Message 8 of 22
marco_suurlant
in reply to: skyngu
You were right the code stopped working because the Tapped Hole has no RetrievedFrom.Parameter.
Here you have the modified code.
Start code”
	Try
	Catch
		' Error to set oParameter.
		' Go further to delete the dimension.
	End Try
            If InStr(oDrivenByParameter.Name, "RetD_") = 0 Then
            End If
        Next
    Else
    End If
Next
“End Code
I didn’t test it with your Part because I have now only version 2011.
Best regards,
Marco Suurlant
Message 9 of 22
skyngu
hi,
at the near end of your code, you miss some parts. it should be like this,
If InStr(oParameter.Name, "test_") = 0 Then
End If
otherwise, the code will delete all dimensions.
thanks for your information.
Message 10 of 22
marco_suurlant
in reply to: skyngu
Something like this:
	Try
	Catch
	End Try
            End If
        Next
	Else
        End If
    End If
Next
Marco Suurlant
Message 11 of 22
achmidt
Guys,
What if I have 3 views and I need to dimension OAL length on the front view, OAL width on the side view, and lets say a hole on the top view. How to modify the code. I tried to play with it, copiyng the part of the code and changing the view name, but it gives me an error.
Thanks in advance.
Message 12 of 22
marco_suurlant
in reply to: achmidt
Here you have some code that can do that, only thing what you must have do is give the Drawing View a name and give the user / model parameter the right name.
Sub Main
RetrieveDimByView(oSheet, "FrontView", "RetD_")
RetrieveDimByView(oSheet, "RightView", "RetDRight_")
RetrieveDimByView(oSheet, "TopView", "RetDTop_")
End Sub
Sub RetrieveDimByView(ByVal oSheet As Sheet, ByVal ViewName As String, ByVal PrefixStr As String)
For Each oDrawView In oSheet.DrawingViews
If oDrawView.Name = ViewName Then
Exit For
End If
Next
Try
Catch
End Try
End If
Next
Else
End If
End If
Next
oSheet = Nothing
End Sub
Marco Suurlant
Message 13 of 22
achmidt
Excellent works just great.
One more question, is there any chance to offset the dimensions?
Message 14 of 22
theo.bot
Hi Marco,
It works fine, but my model is based on a multi body part.
So if i retrieve the dimensions, i get the dimensions from every part from my assembly.
in the standard interface, i can select a part thats part of the view, how can i do this thru the api?
the API help tells me that you can use a "demensionToRetrive":
Sub Retrieve(ViewOrSketch As IDispatch, ByRef DimensionsToRetrieve As [optional] VARIANT, Result As [out, retval] GeneralDimensionsEnumerator*)
I've tried some to create a ObjectCollection with the specific part, but i doesn't seem to work. Do you have any suggestion.
Kind regards,
Theo
Message 15 of 22
marco_suurlant
Hello achmidt,
What you can do is select all dimension and then arrange dimensions.
Start code"
    Dim oCommandMgr As CommandManager = _
    ThisApplication.CommandManager
    oCommandMgr.ControlDefinitions.item("DrawingSelectAllInventorDimsCmd").Execute
    oCommandMgr.ControlDefinitions.item("DrawingArrangeDimensionsCmd").Execute
"End code
Best regards,
Marco Suurlant
Message 16 of 22
Hello Theo,
If you want to make a collection of a Part you can do something like this,
Dim oAssemblyDocument As Inventor.AssemblyDocument = _
	oDrawView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oOcc As Inventor.ComponentOccurrence = _
	oAssemblyDocument.ComponentDefinition.occurrences.item(1)
Dim oGeneralDimensionsObj As ObjectCollection = _
	oSheet.DrawingDimensions.GeneralDimensions.GetRetrievableDimensions(oDrawView, oOcc)
The oGeneralDimensionsObj has now the retrieved dimensions form the first Part.
Best regards,
Marco Suurlant
Message 17 of 22
achmidt
Thanks!!!
Message 18 of 22
achmidt
I`d like to share the code I assembled from different pieces (see attached). Configurator works great but I have few problems with the drawing dimensions.
I`m not sure how to place flat pattern OAL dim`s, can`t place bend dim`s, not sure how to modify flat pattern placement code so it shows bend extents.
oView4 = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint4, ViewScale,kDefaultViewOrientation, kHiddenLineDrawingViewStyle,,, oBaseViewOptions)
 Also I`m not sure how to do ordinate dim`s for the holes (horizontal & vertical).
If you`d like to test it out don`t forget to change the template path and name in the code.
I have an external rule that I run after drawing creation (see below), it places the dimensions I need.
Sub Main
    RetrieveDimByView(oSheet, "VIEW1", "Fr_") ' front view
    RetrieveDimByView(oSheet, "VIEW3", "Rs_") ' right side view
	RetrieveDimByView(oSheet, "VIEW2", "Tv_") ' top view
    'RetrieveDimByView(oSheet, "View3", "RetDTop_")
End Sub
            Exit For
        End If
    Next
        Try
        Catch
        End Try
                End If
            Next
        Else
            End If
        End If
    Next
    oSheet = Nothing
End Sub
 Would be great to add a code that automatically scales up/down the views and places them on the sheet.
Any help appreciated. Thanks,
Message 19 of 22
Prasad.pet
The Following code suggested by you is performing the necessary action but ends with "Unexpected error".
Also it is retrieving the dimension without the special characters like "RteD_". Please guide me.
Try
Catch
End Try
            End If
        Next
Else
        End If
    End If
Next
Message 20 of 22
marco_suurlant
in reply to: Prasad.pet
I have tested the code on my side and it is working, the test part is included.
If it is still not working can you include the part.
Best regards,
Marco
Marco Suurlant
