I have put together some code from some pieces online. It is working well with one exception. It will only replace the 1st and last page titleblocks.
A little background. With our drawings we have a titleblock for page 1 and then we have a titleblock for page 2 and on. The code is replacing the 1st page with the correct (1st) page titleblock and the the last page with the correct (page2) titleblock. The titleblocks in the middle however are getting page 1 titleblocks. Any suggestions would be greatly appreciated. I am very new with iLogic so be gentile:-)
Dim oDrawingDoc As Inventor.DrawingDocument Dim oSheetNumber As Integer Dim oActiveSheetNumber As Integer Dim oActiveSheetName As String Dim oSheet As Sheet Dim oSourceTitleBlockDef As TitleBlockDefinition Dim oNewTitleBlockDef As TitleBlockDefinition oDrawingDoc = ThisApplication.ActiveDocument oActiveSheetName = ActiveSheet.Name oSheet = oDrawingDoc.ActiveSheet If (oSheet.TitleBlock.Name = "page1titleblock") Then oTitleBlockName = "page1titleblock" ElseIf (oSheet.TitleBlock.Name = "page2titleblock") Then oTitleBlockName = "page2titleblock" Else: End If For oSheetNumber = 1 To oDrawingDoc.Sheets.Count oDrawingDoc.Sheets(oSheetNumber).Activate If Not oDrawingDoc.ActiveSheet.TitleBlock Is Nothing Then oDrawingDoc.ActiveSheet.TitleBlock.Delete End If Next oSheetNumber Dim oTitle As TitleBlockDefinition Dim oTitleBlock As TitleBlock For Each oTitle In oDrawingDoc.TitleBlockDefinitions If oTitle.IsReferenced = False Then oTitle.Delete End If Next ThisDrawing.ResourceFileName = "path\to\Template\template.DWG" ThisDrawing.KeepExtraResources = True ActiveSheet.TitleBlock = "page1titleblock" ActiveSheet.TitleBlock = "page2titleblock" oSheetNumber = 1 oDrawingDoc.Sheets(oSheetNumber).Activate ActiveSheet.TitleBlock = oTitleBlockName oSheetNumber = 2 oDrawingDoc.Sheets(oSheetNumber).Activate ActiveSheet.TitleBlock = oTitleBlockName
Solved by GosponZ. Go to Solution.
Solved by NachitoMax. Go to Solution.
Hi
i havent read your code but you will need to itterate through the sheets and replace the titleblock independently. i have made a tool that does this and im in the process of making it into an addin. I will post a video very shortly for you see if it what you are trying to achieve
Nigel
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Hi
See video attached
Nacho
Here is code i'm using to change TB in multi sheets .Make parameter for Border. Insert empty sheet with new TB and run rule . Delete empty sheet
I'm sure there is better way but this one working just fine.
For Each sheetX As Sheet In ThisDrawing.Document.Sheets
ThisDrawing.Sheet(sheetX.Name).TitleBlock = "Your TB"
iLogicVb.UpdateWhenDone = True
ThisApplication.ActiveView.Fit
Next
If Parameter("Border") = "Border" Then
ActiveSheet.Border = "Border"
Hi Molly,
Could you please mark the answer that helped as solution? 🙂
I think it's possible to mark multiple comments like that if you wish.
Cheers,
Tha author of a thread can click "ACCEPT AS SOLUTION" on any comment made.
I also think this can be done on multiple comments of the same thread (if someone wants to) - I'm pretty sure I've seen a thread where multiple comments were greened out. 🙂
Cheers,
