Inventor Customization
Distinguished Contributor
Message 1 of 6 (374 Views)
Replace styles in Drawing
374 Views, 5 Replies
08-24-2012 02:52 AM
Hi
I have some styles I will like to replace in some drawings
but how? I cant find any function to do this.
Do I missing some thing ?
Dim oIDWStyles As Inventor.DrawingStylesManager
 Set oIDWStyles = oDrawDoc.StylesManager
 Dim oldstyle As style
 Dim Newstyle As style
   For Each oldstyle In oIDWStyles.Styles
     If oldstyle.Name = "Old style" Then
       '  Debug.Print oldstyle.Name & " : " & oldstyle.InternalName
        For Each Newstyle In oIDWStyles.Styles
          If Newstyle.Name = "New style" Then
            'Debug.Print Newstyle.Name & " : " & Newstyle.InternalName
            End If
        Next
        'How to replace oldstyle with newstyle
         'oldstyle = Newstyle
     End If
   Next
René J
Message 2 of 6 (366 Views)
Re: Replace styles in Drawing
08-24-2012 05:31 AM in reply to: Rene-J
This worked for me:
' Create the parts list and set a reference to it.
    Dim oPartsList As PartsList
    Set oPartsList = oSheet.PartsLists.Add(oDrawingView1, oPlacementPoint)
    oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("PARTS LIST PART")
Hope this helps.
Chris
*Expert Elite*
jdkriek
Message 3 of 6 (364 Views)
08-24-2012 05:43 AM in reply to: Rene-J
You can rename it, delete it, set another style as the object default, but no direct replace that I know of.
If you set the new styles as object defaults, then you could change all elements to the active standard.
Jonathan D. Kriek
Autodesk Inventor Certified Expert
Microsoft Certified Application Developer
_____________________________________________________
Did I help you? Please choose Accept as Solution or Kudos below
Message 4 of 6 (357 Views)
08-24-2012 05:57 AM in reply to: jdkriek
UGHHHH....I swear I read "parts list style" the first time I read your post!  Thats what I get for responding before I've had some caffeine!
*Expert Elite*
jdkriek
Message 5 of 6 (355 Views)
08-24-2012 06:04 AM in reply to: cmines
Get some coffee, it will be alright - for a Friday :smileywink:
Jonathan D. Kriek
Message 6 of 6 (324 Views)
09-05-2012 08:59 AM in reply to: jdkriek
Thanks Jonathan
Finally I got the time, to look at your suggestion.
I'm sorry I have not commented earlier, I've been on vacation.
I thought there was an easier solution.
René J
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
