Rename and save using iLogic
30 REPLIES 30
Message 1 of 31
Leecrawford0406
12732 Views, 30 Replies
Hi
I am having a bit of trouble finding the correct code for some automated ilogic in inventor 2011.
I am trying to achieve an automated rename and save process for an assembly file as well as the variable parts in the file.
an example would be a steel column...
Open ilogic steel column, run rules to change column length and section size...
then save a copy to workspace, but also to a specific folder in the workspace..
also rename the column file and save.
i have this for file saving -
SyntaxEditor Code Snippet
Test=InputBox("Add File name", "Please Add your file name", "Prefix number - File - .iam")
ThisDoc.Document.SaveAs(ThisDoc.WorkspacePath()&Test, True)
Which works fine to save the new assembly, but i need the same for the variable column within the assembly, and also to save to a specific folder not just the workspace top level.
Any help would be greatly appreciated
Regards
Lee
30 REPLIES 30
Message 2 of 31
SteveX82
in reply to: Leecrawford0406
I was hoping to see more replies to your post, as I'm encountering similar difficulties with a "Configurator" I am working on.
The biggest limitation seems to come from the ThisDoc.Document.Saveas, which doesn't permit you to "save as" any components within your assembly (ie, you can only Save As your top level assembly where the rule is). There is also a FileCopy command that one could conceivaby use on components, but that only copies out the part file as it was last configured and saved. I haven't found a way to SaveAs the newly configured part as stored in RAM, which seems to be what you desire.
As for file save locations, be advised that you can structure them either relatively (as you already are) or absolutely.
For example:
Relative location in a subfolder within your workspace named after your new assembly number. Note that I changed the code to instruct the user just to addd the file name without the extension. The if statement creates a new subfolder specific to your new subassembly if it doesn't already exist.
Test=InputBox("Add File name", "Please Add your file name", "Prefix number - File")
If (Not System.IO.Directory.Exists(Test)) Then
     System.IO.Directory.CreateDirectory(Test)
End If
ThisDoc.Document.SaveAs(Test & "\" &Test &".iam", True)
or
Absolute location (assuming the destination folder already exists):
ThisDoc.Document.SaveAs("C:\Workspace\newfiles\" &Test &".iam", True)
Hope this helps a bit and that it prompts some more discussion.
Message 3 of 31
danvang
in reply to: SteveX82
Here's some code that I wrote that may help with what you are looking at doing. This is only for a single part and it's drawing. I do have one that's for the assembly, parts, assembly drawing and part drawings. Copy and paste this into a rule. Hope this helps.
Sub Main
    'get the filepath of this document
    Dim sFilePath As String= ThisDoc.Path & "\"
    'get the active document
    doc = ThisDoc.Document
    'declare variable for drawing
    Dim oDestinationDoc As DrawingDocument
    'declare variable for new name and original name
    Dim sNewName As String
    Dim sOrgName As String = doc.DisplayName
    'get the new filename from the input box
    sNewName = InputBox("What is the new file name for " & doc.DisplayName & "?", "New File Name", doc.DisplayName)
    'if the new file name is blank then use the same name
    If sNewName = "" Then
        sNewName = sOrgName
    End If
    'if the user also types in the extension then remove the extension.
    If sNewName.EndsWith(".ipt") = True Then
        sNewName = sNewName.substring(0,sNewName.length-4)
    End If
    'if there is an change in the name then do the following.
    If doc.DisplayName <> sNewName & ".ipt" Then
        'check to see the file already exist. If the file does not exist then... If it does exist, do nothing
        If System.IO.File.Exists(sFilePath & sNewName & ".ipt") = False Then
            'set the old file name. will need this to find the idw. no extension
            sOrgName = sOrgName.substring(0,sOrgName.Length-4)
            'if it does not exist then create the file
            doc.saveas(sFilePath & sNewName & ".ipt",False)
            'call sub to update the drawing file.
            Call UpdateDrawing(sFilePath, sOrgName, sNewName)
        End If
    End If
End Sub
Private Sub UpdateDrawing (ByVal Path As String, ByVal oldName As String, ByVal newName As String)
    'declare variable for drawing document
    'declare variable for the original idw.
    Dim sFileName As String = Path & oldName & ".idw"
    Try
        'if the original idw file exist then.....
        If System.IO.File.Exists(sFileName) Then
            'open the original idw
            oDestinationDoc = ThisApplication.Documents.Open(sFileName)
            'save the original idw as the new file name. The new idw will be the same name as the ipt
            oDestinationDoc.saveas(Path & newName & ".idw",False)
            'next we need to update the new idw to look at the new ipt.
            'declare variables
            Dim oDocDescriptor As DocumentDescriptor
            oDocDescriptor = oDestinationDoc.ReferencedDocumentDescriptors.Item(1)
            Dim oFileDescriptor As FileDescriptor
            oFileDescriptor = oDocDescriptor.ReferencedFileDescriptor
            'replace the original ipt file with the new ipt in the new idw.
            oFileDescriptor.ReplaceReference(Path & newName & ".ipt")
            'update the drawing
            oDestinationDoc.Update()
            'close the drawing
            oDestinationDoc.Close
        End If
    Catch
    'if there's an issue, close the drawing and show error
        MessageBox.Show("Cannot update the drawing")
    End Try
End Sub
** If my reply resolves this issue, please choose "Accept as Solution" **
Dan Vang
Message 4 of 31
SteveX82
in reply to: danvang
Do you have any more info on your code for "the assembly, parts, assembly drawing, and part drawings"? It sounds interesting and should be what Lee is looking for.
Also, where did you learn about the additional coding that iLogic can handle? The Snippets built into the Rule Editor are pretty limited, but it seems like Inventor can understand and use much more. Can you point Lee and me towards some useful references?
For example, I notice that you dimension oDestinationDoc as a "DrawingDocument", but what kind of syntax would one use for an ipt or iam file?
Message 5 of 31
danvang
Here is the code for the assembly. place this in a rule in the assembly file. There is one thing to be aware of, because i am using the displayname to get the name of the file, you will need to display file extensions for known file types in Windows Explorer.
The syntax that I am using is from the Inventor API.
Hope this helps.
Sub Main()
Dim Path As String = ThisDoc.Path & "\"
Dim FileChange As Boolean = False
InvDoc = ThisDoc.Document
Dim refDocs As DocumentsEnumerator = InvDoc.AllReferencedDocuments
Dim refDoc As Document
For Each refDoc in refDocs
'MessageBox.show(refDoc.DisplayName)
'input box to enter new file name
NewFileName = InputBox("What is the new file name for " & refDoc.DisplayName & "?", "New File Name", refDoc.DisplayName)
'NewFileName = InputBox("What is the new file name for " & refDoc.DisplayName & "?", "New File Name", iProperties.Value(refDoc.DisplayName, "Project", "Part Number"))
    If NewFileName = "" Then
        NewFileName = refDoc.DisplayName
    End If
    'if the user also types in the extesion then remove the extension.
    If NewFileName.EndsWith(".ipt") = True Then
        NewFileName = NewFileName.substring(0,NewFileName.length-4)
        'MessageBox.show(NewFileName)
    End If
    If refDoc.DisplayName <> NewFileName & ".ipt" Then
        'check to see the file already exist. if it does then replace.
        If System.IO.File.Exists(Path & NewFileName & ".ipt") Then
            Component.Replace(refDoc.DisplayName, Path & NewFileName & ".ipt", True)
        Else
            Dim oldName As String = refDoc.DisplayName
            'if it does not exist then recreate the file
            refDoc.saveas(Path & NewFileName & ".ipt",False)
            Call UpdateDrawing(Path, oldName, NewFileName)
        End If
        FileChange = True
    End If
Next
If FileChange = True Then
    NewAssemblyName = InputBox("What is the new file name for the assembly?", "New Assembly File Name", iProperties.Value("Project", "Part Number"))
    If NewAssemblyName <> "" Then
        Dim oldName As String = ThisDoc.FileName(True) 'include extension
        ThisDoc.Document.SaveAs(Path & NewAssemblyName & ".iam" , False)
        Call UpdateDrawing(Path, oldName, NewAssemblyName)
    End If
End If
iLogicVb.UpdateWhenDone = True
End Sub
    Dim strFileExtension As String = oldName.substring(oldName.Length-4,4)
    oldName = oldName.substring(0,oldName.Length-4)
    Try
            oFileDescriptor.ReplaceReference(Path & newName & strFileExtension)
        End If
    Catch
        MessageBox.Show("error")
    End Try
End Sub
Dan Vang
Message 6 of 31
mijobrand
Hi I have found this info useful but would like to modify it slightly so that it  saves the .ipt files and .idw files to a new folder location based on iproperties within the model. I can achive this on the .ipt level with the altered code but the drawing does not copy to the new folder location.
Format:HTML Format Version:1.0 StartHTML:     165 EndHTML:   30566 StartFragment:     314 EndFragment:   30534 StartSelection: 314 EndSelection:     314
SubMain'get the filepath of this documentDimsFilePathAsString="C:\Vault Workspace\Customers"&"\"&Customer&"\"&Job_Tag&"\"&SalesOrderNumber&"\"'get the active documentdoc=ThisDoc.Document'declare variable for drawingDimoDestinationDocAsDrawingDocument'declare variable for new name and original nameDimsNewNameAsStringDimsOrgNameAsString=doc.DisplayName'get the new filename from the input boxsNewName=InputBox("What is the new file name for "&Gauge&" ga "&Material_type&" - "&Part_Name&"?", "New File Name", Gauge&" ga "&Material_type&" - "&Part_Name)'if the new file name is blank then use the same nameIfsNewName=""ThensNewName=sOrgNameEndIf'if the user also types in the extension then remove the extension.IfsNewName.EndsWith(".ipt")=TrueThensNewName=sNewName.substring(0,sNewName.length-4)EndIf'if there is an change in the name then do the following.Ifdoc.DisplayName<>sNewName&".ipt"Then'check to see the file already exist. If the file does not exist then... If it does exist, do nothingIfSystem.IO.File.Exists(sFilePath&sNewName&".ipt")=FalseThen'set the old file name. will need this to find the idw. no extensionsOrgName=sOrgName.substring(0,sOrgName.Length-4)'if it does not exist then create the filedoc.saveas(sFilePath&sNewName&".ipt",False)'call sub to update the drawing file.CallUpdateDrawing(sFilePath, sOrgName, sNewName)EndIfEndIfEnd Sub
PrivateSubUpdateDrawing(ByValPathAsString, ByValoldNameAsString, ByValnewNameAsString)'declare variable for drawing documentDimoDestinationDocAsDrawingDocument'declare variable for the original idw.DimsFileNameAsString=Path&oldName&".idw"Try'if the original idw file exist then.....IfSystem.IO.File.Exists(sFileName)Then'open the original idwoDestinationDoc=ThisApplication.Documents.Open(sFileName)'save the original idw as the new file name. The new idw will be the same name as the iptoDestinationDoc.saveas(Path&newName&".idw",False)'next we need to update the new idw to look at the new ipt.'declare variablesDimoDocDescriptorAsDocumentDescriptoroDocDescriptor=oDestinationDoc.ReferencedDocumentDescriptors.Item(1)DimoFileDescriptorAsFileDescriptoroFileDescriptor=oDocDescriptor.ReferencedFileDescriptor'replace the original ipt file with the new ipt in the new idw.oFileDescriptor.ReplaceReference(Path&newName&".ipt")'update the drawingoDestinationDoc.Update()'close the drawingoDestinationDoc.CloseEndIfCatch'if there's an issue, close the drawing and show erroroDestinationDoc.CloseMessageBox.Show("Cannot update the drawing")EndTry
End Sub
Message 7 of 31
LSA-skan
in reply to: mijobrand
Hi
Im struggeling with what it seems you guys might have a solution for...!
Short.: i would like to copy specific parts, in my assy. (allso a configurable assy), they are specific by name and location..! also the target location is  always the same...
My current thread is here..:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Assembly-Save-As-incl-some-parts-With-...
Even though this is an old tread i hope some of you are still available to help 🙂
/LSA
Message 8 of 31
danvang
in reply to: LSA-skan
I replied to you in your other post.
Dan Vang
Message 9 of 31
mbranderhorst
danvang.
   I have been using this code with slight modifications for some time and have had great results. I have it running on 2 machines seamlessly but I have a third machine setup that i can't get to function properly. the code is exactly the same as the other 2 machines. The issue i am having is with the coping of the drawing to the new location. I have added message box code (see below) to determine where the code fails and have determined that it is   this line "If System.IO.File.Exists(sOldFileName) Then"
    Try
                MessageBox.Show("I got past the if statment")
Any help in resolving this issue would be much appreciated.
Message 10 of 31
danvang
in reply to: mbranderhorst
Not sure why it would not work but here are some troubleshooting methods you can try.
1. Place a message box to show sOldFileName before the if. Run the rule and check to see if the syntax for sOldFileName is correct.
2. The person who is logged in on the third computer, does the person have access to the directory?
3. In Windows Explorer, show the file extensions for known file types.
If it still does not work then attach your code and I can take a look at it.
Dan
Dan Vang
Message 11 of 31
Dan, the problem seemed to be the hidden extensions. Once it was changed all worked fine.
Thanks.
Mike
[small new logo]
Mike Branderhorst
Production designer
Andex Metal Products
519 235 2901 ext 129
mbranderhorst@agwaymetals.com
Check out our new website at www.agwaymetals.com
Message 12 of 31
falkmassmann
Hi Dan,
thanks for posting your code. It helped me a lot in solving my problem.
I changed your code for my specific task. I want to copy an assembly to a workspace path while ignoring content center parts. So here is my code for helping others to achieve their goals.
Sub Main()
	Dim Path As String = ThisDoc.WorkspacePath & "\"
	Dim oldPath As String = ThisDoc.Path & "\"
	MessageBox.Show(Path, "Workspace-Pfad")
	MessageBox.Show(oldPath, "alter Workspace-Pfad")
	oInvDoc = ThisDoc.Document
	Dim refDocs As DocumentsEnumerator = oInvDoc.AllReferencedDocuments
	For Each refDoc In refDocs
		'MessageBox.Show(refDoc.Type)
		'MessageBox.Show(refDoc.DocumentType)
		'detect If document Is Assembly And save As Assembly
		If refDoc.DocumentType = 12291 Then
			'define new Name for copy of the referenced document
			NewFileName = InputBox("Geben Sie den neuen Namen für die Baugruppe " & refDoc.DisplayName &" ein!","New File Name", refDoc.DisplayName)
			'check For blank filename And Set To DisplayName
			End If
			'check For extension In name And remove If there
			If NewFileName.EndsWith(".iam") = True Then
				NewFileName = NewFileName.Substring(0,NewFileName.length-4)
				'MessageBox.Show(NewFileName)
			End If
			refDoc.SaveAs(Path & NewFileName & ".iam",False)
		Else
			'initialize object for PartComponentDefinition to access property if part is member of content center
			Dim oPartCompDef As PartComponentDefinition
			oPartCompDef = refDoc.ComponentDefinition
			If Not oPartCompDef.IsContentMember Then
				NewFileName = InputBox("Geben Sie den neuen Namen für das Bauteil " & refDoc.DisplayName &" ein!","New File Name", refDoc.DisplayName)
				End If
				End If
				refDoc.SaveAs(Path & NewFileName & ".ipt",False)
			Else
				MessageBox.Show("Die Komponente " & refDoc.DisplayName & "ist ein Content Center Part und wird nicht kopiert !")
			End If
		End If
	Next
		NewAssemblyName = InputBox("Wie lautet der neue Name für die Haupt-Baugruppe?", "Neuer Baugruppenname", ThisDoc.FileName(True))
		If NewAssemblyName = "" Then
			NewAssemblyName = ThisDoc.FileName(True)
			If NewAssemblyName.EndsWith(".iam") = True Then
				NewAssemblyName = NewAssemblyName.Substring(0,NewAssemblyName.length-4)
			End If
			'MessageBox.Show(NewAssemblyName,"Alter Baugruppenname")
			ThisDoc.Document.SaveAs(Path & NewAssemblyName & ".iam" ,False)
		Else
			'MessageBox.Show(NewAssemblyName, "Neuer Baugruppenname")
			End If
			ThisDoc.Document.SaveAs(Path & NewAssemblyName & ".iam",False)
		End If
		Dim ctrl As ControlDefinition
		ctrl = ThisApplication.CommandManager.ControlDefinitions("AppSaveAllCmd")
		ctrl.Execute()
End Sub
What I need to do is copy the related drawings. My question here is about your structure of code, you´re using a sub for the drawing part. Can I use functions in my rule that I can call in the Main sub() and if I can what options do I have to set that this is working.
best wishes
P.S: Had to delete my first post cause the code was pretty much unreadable. Anyone knows what´s the best method to copy and paste code into this forum?
Message 13 of 31
danvang
in reply to: falkmassmann
Falkmassmann,
If your are asking if you can use functions in an iLogic rule, the answer is yes. Just remember that with a Function you have to return something. A Sub you do not. Here's a quick example of using a function in an iLogic rule. Hope that helps.
Sub Main()
Dim MessageValue As Integer = 1
Dim MessageNote As String
MessageNote = TestMessageFunction(MessageValue)
MessageBox.Show(MessageNote)
End Sub
Private Function TestMessageFunction(ByVal MessageValue As Integer) As String
Dim MessageType As String
If MessageValue = 1 Then
    MessageType = "Test note 1"
Else
    MessageType = "Test note other"
End If
Return MessageType
End Function
Dan Vang
Message 14 of 31
falkmassmann
Thank you Dan,
that cleared things up.
I´ve run into another minor problem which I can´t resolve.
In my code I´m reading the old displayname and write it back to the copied files because I´ve an iLogic script that controls components in the assembly.
Actually it just links parameters from the main assembly to components in the assembly, if I change displaynames those linked connections won´t work anymore.
When I try to write back the displayname from the main assembly it´s always missing the ".iam" part at the end even if I put it in manually.
It´s not a big issue, I will probably leave it as it is since it won´t affect the link to the parameters.
All the best
Falk
Message 15 of 31
itjelta
reviving an old thread here
Can this code also include idw?
Message 16 of 31
mijobrand
in reply to: itjelta
Itjelta, if you have a .idw already created and saved for the first part
this code will and should take the part and drawing and rename both.
mijobrand
Message 17 of 31
itjelta
Yes, I noticed that it do, but for some reason the idw won't update parts with the new parts.
All assembly views are updated, but my parts list, and (single part view) is not updated)
But I suppose it's something with some custom configurations on our company's templates.
Thanks for reply 🙂
Message 18 of 31
tony
Hi Danvang,
Your rename and save code looks like a great time saver when updating the file name for a part and drawing.
I've tested your code in a part file (template) no problem with the part file number updating but have been unable to get the drawing file number to update. I'm wondering if there are some other rules that need to be saved to the drawing template or some specific "Copy Model iproperties  Settings"?
Thanks in advance
Tony.
Message 19 of 31
danvang
in reply to: tony
Tony,
When I originally wrote this, I didn't recall seeing that the part numbers weren't updating. I'm wondering over the years something changed because the code is simply doing a SAVEAS which if it's done Inventor should update the part number. That or I just over looked it as well. But thanks for point that out. Here is what you can probably do to update the part number in the model and also the part number in the associated drawing. Hope this helps.
Sub Main
        sNewName = sOrgName
    End If
    End If
   iProperties.Value("Project", "Part Number") = sNewName  '***this updates the part number value in the model
        End If
    End If
End Sub
    Try
            'declare variables
            Dim oPropSet As PropertySet = oDestinationDoc.PropertySets.Item("Design Tracking Properties")
            oPropSet.item("Part Number").Value = newName   '***this updates the part number value in the drawing
            'update the drawing
            'close the drawing
        End If
    Catch
    End Try
End Sub
Dan Vang
Message 20 of 31
tony
Hi Danvang,
I appreciate your help with this but I may have misinterpreted the function
of your icode?
Can your code be modified to "Save Copy As" the linked drawing with the new
file number?
I.e. If a part file and drawing has a new revision and the part file number
12345.ipt is copied and saved as 12345.A.ipt (using your icode) the existing
drawing 12345.idw will be copied and saved as 12345.A.idw.
Thankyou
Tony
