Hello Everyone,
I have a little understanding in Ilogic but manage to do some basic customization.
My objective in the Pipe Spool assembly is that anytime the pipe size change both the flanges and pipe part will resize within the assembly. I already resolve this using creating Ilogic Rule and the new parts are creating at the background
My next objective is the Pipe and Flanges will be automatically replaced by the new size (newly created part). This is the area I'm having a problem. Anyone could help me with this one?
The Rule that I created is base in this link:
Assembly Rule:
fmgr = ThisApplication.Filemanager For Each file In fmgr.files doc = ThisApplication.Documents.ItemByName(file.fullfileName) compdef = doc.ComponentDefinition If (doc.documenttype = 12291) Then ' only do this for assembly or subassembly For Each occ In compdef.Occurrences If (occ.definition.type =83886592) Then ' only do this for part Parameter.Quiet = True If Parameter(occ.Name, "length") AndParameter(occ.Name, "length") And Parameter(occ.Name,"length") Then Parameter(occ.Name, "length") = Ceil( 10*(occ.definition.RangeBox.MaxPoint.X -occ.definition.RangeBox.MinPoint.X)) Parameter(occ.Name, "width") = Ceil( 10*(occ.definition.RangeBox.MaxPoint.Y -occ.definition.RangeBox.MinPoint.Y)) Parameter(occ.Name, "height") = Ceil( 10*(occ.definition.RangeBox.MaxPoint.Z -occ.definition.RangeBox.MinPoint.Z)) iLogicVb.RunRule(occ.Name, "Part number") Component.Replace(occ.Name,iProperties.Value(occ.Name,"Project", "Part Number") &".ipt", False) occ.Name = iProperties.Value(occ.Name,"Project","Part Number") End If End If Next occ End If Next file InventorVb.DocumentUpdate()
From there I customize the Rule:
(Need help to include a code for "Automatic Replace Component")
fmgr = ThisApplication.Filemanager For Each file In fmgr.files doc = ThisApplication.Documents.ItemByName (file.fullfileName) compdef = doc.ComponentDefinition If (doc.documenttype = 12291) Then ' only do this for assembly or subassembly For Each occ In compdef.Occurrences If (occ.definition.type =83886592) Then ' only do this for part Parameter.Quiet = True Parameter(occ.Name, "Size") = Size Parameter(occ.Name, "LG") = LG iLogicVb.RunRule(occ.Name, "Save As") End If Next occ End If Next file
Please see also attached file of the assembly I am working on. Thanks!!!
Solved by jdkriek. Go to Solution.
I added the "Component.Replace" and now the parts are being replace by the new defined size.
However, what I noticed is the Component Occurence Name does not change accorrding to size.
What code I need to add to resolve this issue?
fmgr = ThisApplication.Filemanager For Each file In fmgr.files doc = ThisApplication.Documents.ItemByName (file.fullfileName) compdef = doc.ComponentDefinition Dim occ As ComponentOccurrence If (doc.documenttype = 12291) Then ' only do this for assembly or subassembly For Each occ In compdef.Occurrences If (occ.definition.type =83886592) Then ' only do this for part Parameter.Quiet = True Parameter(occ.Name, "Size") = Size1 Parameter(occ.Name, "LG") = LG1 iLogicVb.RunRule(occ.Name, "Save As") Component.Replace(occ.Name,iProperties.Value(occ.Name,"Project", "Part Number") &".ipt", False) ' New added line to replace the component Next occ End If Next file
Try this, it will reset the Occurrence name back to it's default - which will update it to show the new size.
If ThisDoc.Document.DocumentType = 12291 Then 'If Assy Doc Dim oAssy As AssemblyDocument = ThisApplication.ActiveDocument Dim thisOcc As Integer 'Go through all Occurrences For thisOcc = 1 To oAssy.ComponentDefinition.Occurrences.count 'Reset name to default oAssy.ComponentDefinition.Occurrences(thisOcc).Name = "" Next thisOcc End If
I would like to run a ilogic rule in any assembly environment so that it has to allow me to rename components in series say "A01, A02....or PJ12, PJ13 or in any series ".
I had tried the code, please refer to the attachment, this code worked well, it had renamed all the components in assembly environment.
But when I open the part file in a separate window, the component name is reverted back to old one before applying iLogic code.
Please let me know how to fix this.
Mahesh
Thanks a lot for the code snippet in iLogic. I used this snippet and wrote the following VB .NET program to replace and rename component in assembly
Sub CompReplace(oldPart As String, newPart As String, newCompName As String)
Try
If (Not (System.IO.File.Exists(newPart))) Then
MessageBox.Show("CompReplace -- New replacement part File >" + newPart + "< does not exist")
Return
End If
' Top-level assembly document and assembly component definition
Dim oDoc As AssemblyDocument
oDoc = InventorApplication.ActiveDocument
Dim oAsmDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
'Iterate through all of the occurrences at the top level
For Each oOcc As ComponentOccurrence In oAsmDef.Occurrences
'get name of this occurrence
Dim compName As String = oOcc.Name
MessageBox.Show("CompReplace --- Comp Occurence Name >" + compName + "<")
If (UCase(compName) = UCase(oldPart)) Then
MessageBox.Show("CompReplace -- Component Match found")
' Replace the identified part with the replacement part
oOcc.Replace(newPart, False)
oOcc.Name = newCompName
MessageBox.Show("CompReplace -- Component Replaced AND Renamed")
Exit For
End If
Next
Catch ex As Exception
MessageBox.Show(ex.Message)
MessageBox.Show(ex.StackTrace)
End Try
End Sub
