Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Rename Sheets - Multi Sheet idw
1 REPLY 1
rob.j.ross
687 Views, 1 Reply
I need to rename the sheets of a multiple sheet idw.  This should be easy but for some reason I cannot change the sheet names.  I get no errors it just does not change.  Here is the VBA code:
 'Open drawing document
Set oDrawingDoc = ThisApplication.Documents.Open(sPath, True)
'Set the sheets collection
Set oSheets = oDrawingDoc.Sheets
 'Cycle through sheets
For Each oSheet In oSheets
            If oSheet.Name = "Test:1" Then
                oSheet.Activate
                oSheet.Name = "New Sheet Name:1"
            Else
            End If
            oSheet.Update
Next
oDrawingDoc.Update
oDrawingDoc.Save
oDrawingDoc.Close
____________________________
Inventor Professional 2014 64 Bit
Windows 7 Professional
NVIDIA Quadro FX 4600
Dual Intel Xeon E5540 CPUs
16GB DDR3 Ram
1 REPLY 1
rob.j.ross
in reply to: rob.j.ross
Found the problem.  oSheet.Name = "New Sheet Name:1" should not include the ":1" at the end.
16GB DDR3 Ram
