Inventor Customization
Active Contributor
r.ernstberger
Message 1 of 3 (318 Views)
Registry-free C++ AddIn with Inventor 2013 and Visual Studio 2010
318 Views, 2 Replies
11-15-2012 01:52 AM
Hi all,
i'm trying to move my C++ AddIn from Inventor 2010 to 2013.
I've read about the new type of registry free Addin.
I've downloaded the updated Developer Tools and created a new blank project with the wizard.
This works fine.
But by comparing the new projects structure with my current one in 2010 i see lots of differences.
Searching through the C++-Samples in the SDK directory i found none of them updated to the new version of Visual Studio and to registry free.
So i would kindly ask for a sample project (Visual Studio 2010, C++, registry free)
which will show a suitable way of implementing commands.
I'm also looking for a sample which inserts buttons and groups to the ribbon.
I've also read about a AddIn vor Visual Studio 2010 (creeating a toolbar) that should be installed by the Developer Tools for Inventor 2013.
My installation of the Developer Tools finished without any error but i can see no AddIn in Visual Studio 2010.
Is there a way to set up the AddIn manually?
Thanks in advance for any help or suggestions.
Richard
ADN Support Specialist
xiaodong.liang
Message 2 of 3 (297 Views)
Re: Registry-free C++ AddIn with Inventor 2013 and Visual Studio 2010
11-21-2012 08:16 PM in reply to: r.ernstberger
Hi
It is same to implement commands, creating custom interface in registry-free and registry addin. You can still use the same codes in registry-free.
clarify: no toolbar for VS. long time ago (long before 2010), the wizard did created a toolbar. But no toolbar anymore. The wizard just provides you the template of project to create addin.You will need to create commands, add interface yourself.
But, I think the AU material will be of much help for you. My colleauge Philippe prodduced some templates of custom interface, commands, events for developer's convenience.
http://au.autodesk.com/?nd=class&session_id=9028
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Active Contributor
r.ernstberger
Message 3 of 3 (272 Views)
12-06-2012 03:30 AM in reply to: xiaodong.liang
Hi Xiaodong,
thank you for the reply and the interesting link.
Though the material is targeted to C# and VB while my problem is with C++ i really enjoyed the explanation of the autoload mechanism via the .addin files.
But a real help for me was your post 'Notes for migrating C++ add-in to registry free' on adndevblog.typepad.com/manufacturing.
This helped me a lot and i was able to convert the rather old project to registry-free.
Many thanks,
Richard
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
