Hi all,
I'm trying to resolve a document by using OnResolvedocument as one of the file access events. I have installed the events as well. I could able to see the addin template in vb.net templates. But, When I'm trying to add the file access event into my Project, it is prompting an error as shown in attachment. Please find.
Someone's help would be appreciated.
Thanks in advance.
Regards
NKalyan
NullReferenceException occurs when you try to reference an object in your code that does not exist.
For example, you may have tried to use an object without using the New keyword first, or tried to use an object whose value is set to null (Nothing in Visual Basic).
I strucked-up at OnResolve document event in the code. Can someone check the code and let me know what exactly need to be done if the drawing is missing its reference.
Anyone's help would be greatly appreciated.
Regards
NKalyan
Hi everyone,
I got the correct API and the code should be as given below...
Instead of resolving the document, it could be ReplaceReference.
oDwg.ActiveSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference(oRefFilename)
Might be useful for anyone who's trying to Resolve the documents using VB.net
Regards
NKalyan
