PublicSub Activate( _
ByVal addInSiteObject As Inventor.ApplicationAddInSite, _
ByVal firstTime AsBoolean) _
Implements Inventor.ApplicationAddInServer.Activate
' Inventor application
m_inventorApplication = addInSiteObject.Application
' get the command manager control definition
Dim conDefs As Inventor.ControlDefinitions = _
m_inventorApplication. _
CommandManager.ControlDefinitions
' our custom command ID
Dim idCommand1 AsString = "ID_COMAND_1"
Try
' try get the existing command definition
_defComando1 = conDefs.Item(idCommand1)
Catch ex AsException
' or create it
_defComando1 = conDefs.AddButtonDefinition( _
"Command 1", idCommand1, _
CommandTypesEnum.kEditMaskCmdType, _
Guid.NewGuid().ToString(), _
"Command 1 description", _
"Command 1 Tooltip", _
GetICOResource("ProjetName.StdIcon.ico"), _
GetICOResource("ProjetName.Large.ico"))
EndTry
If (firstTime) Then
If (m_inventorApplication.UserInterfaceManager.
InterfaceStyle =
InterfaceStyleEnum.kRibbonInterface) Then
' 1. access the Zero Doc ribbon
Dim ribbonPart As Inventor.Ribbon =
Ribbons.Item("ZeroDoc")
' 2. create our custom tab
Dim tabSampleBlog As Inventor.RibbonTab =
ribbonPart.RibbonTabs.Add( _
"Sample Blog", _
"TAB_SAMPLE_BLOG", _
Guid.NewGuid().ToString())
' 3. criar um painel
Dim pnlMyCommands As Inventor.RibbonPanel =
tabSampleBlog. _
RibbonPanels.Add("My Command", _
"PNL_MY_COMMANDS", _
' 4. colocar o botão no painel
pnlMyCommands.CommandControls.AddButton(_defComando1, True)
EndIf
EndIf
' register the method that will be executed
AddHandler _defComando1.OnExecute, AddressOf Command1Method
EndSub
' must be declared at the class level
Private _defComando1 As Inventor.ButtonDefinition
PrivateSub Command1Method()
' ToDo: do your code here
EndSub
PrivateFunction GetICOResource( _
ByVal icoResourceName AsString) AsObject
Dim assemblyNet As System.Reflection.Assembly = _
System.Reflection.Assembly.GetExecutingAssembly()
Dim stream As System.IO.Stream = _
assemblyNet.GetManifestResourceStream(icoResourceName)
Dim ico As System.Drawing.Icon = _
New System.Drawing.Icon(stream)
ReturnPictureDispConverter.ToIPictureDisp(ico)
EndFunction
The PictureDispConverter converter is based on this AU class by Philippe Leefsma. Below is the piece required here converted to VB.NET
PublicNotInheritableClassPictureDispConverter
<DllImport("OleAut32.dll",
EntryPoint:="OleCreatePictureIndirect",
ExactSpelling:=True, PreserveSig:=False)> _
PrivateSharedFunction OleCreatePictureIndirect( _
<MarshalAs(UnmanagedType.AsAny)> picdesc AsObject, _
ByRef iid AsGuid, _
<MarshalAs(UnmanagedType.Bool)> fOwn AsBoolean _
) AsIPictureDisp
EndFunction
Shared iPictureDispGuid AsGuid = GetType( _
IPictureDisp).GUID
PrivateNotInheritableClassPICTDESC
PrivateSubNew()
EndSub
'Picture Types
PublicConst PICTYPE_UNINITIALIZED AsShort = -1
PublicConst PICTYPE_NONE AsShort = 0
PublicConst PICTYPE_BITMAP AsShort = 1
PublicConst PICTYPE_METAFILE AsShort = 2
PublicConst PICTYPE_ICON AsShort = 3
PublicConst PICTYPE_ENHMETAFILE AsShort = 4
<StructLayout(LayoutKind.Sequential)> _
PublicClassIcon
Friend cbSizeOfStruct AsInteger = Marshal.SizeOf( _
GetType(PICTDESC.Icon))
Friend picType AsInteger = PICTDESC.PICTYPE_ICON
Friend hicon AsIntPtr = IntPtr.Zero
Friend unused1 AsInteger
Friend unused2 AsInteger
FriendSubNew(icon__1 As System.Drawing.Icon)
Me.hicon = icon__1.ToBitmap().GetHicon()
EndSub
EndClass
PublicClassBitmap
GetType(PICTDESC.Bitmap))
Friend picType AsInteger = PICTDESC.PICTYPE_BITMAP
Friend hbitmap AsIntPtr = IntPtr.Zero
Friend hpal AsIntPtr = IntPtr.Zero
Friend unused AsInteger
FriendSubNew(bitmap__1 As System.Drawing.Bitmap)
Me.hbitmap = bitmap__1.GetHbitmap()
EndSub
EndClass
EndClass
PublicSharedFunction ToIPictureDisp( _
icon As System.Drawing.Icon _
) AsIPictureDisp
Dim pictIcon AsNewPICTDESC.Icon(icon)
Return OleCreatePictureIndirect(pictIcon, _
iPictureDispGuid, True)
EndFunction
bmp As System.Drawing.Bitmap _
) AsIPictureDisp
Dim pictBmp AsNewPICTDESC.Bitmap(bmp)
Return OleCreatePictureIndirect(pictBmp, _
EndFunction
EndClass
